Motorcycle tank repiar?
bigfoot584
Re: Motorcycle tank repiar?
Post by bigfoot584 » Sun Jan 04, 2015 10:53 am
Chipped tooth wrote:I could probably Tig it but I don't want to ruin the paint.
It's gonna sit over winter with gas in it and see if it holds
Hey bud, unless you tig weld that, it'll always be in the back your mind
when and if it'd going to leak and when it dose you know he'll be out in the
middle of no where, bite the bullet and tig it really. Do short cold welds,
you can get pretty damn close to a painted surface and not harm it.
Chipped tooth
Post by Chipped tooth » Thu Jan 08, 2015 7:03 am
I was thinking a wet rag and as you stated slow small welds are probably the best bet.
I just don't have much faith in epoxy vs gasoline formulas.
Kevin Johnson
Post by Kevin Johnson » Mon Jan 12, 2015 5:53 am
Chipped tooth wrote:I was thinking a wet rag and as you stated slow small welds are probably the best bet.
Good thought.
David Redszus previously wrote: A few years ago, I tested two batches of Shell pump gasoline obtained from the same station but a week apart. The first sample contained 542 different compounds, the second only 484 different compounds. In addition, both blends contained a number of "unidentified" compounds. There is no such thing as pump gas; only pump gasolines of which there are very, very many.
Monza Harry
Post by Monza Harry » Sun Jan 25, 2015 10:26 pm
As for the Paint have you ever tried this? http://www.eastwood.com/coldshield-thermal-paste.html or this? http://www.eastwood.com/ew-anti-heat-compound-1-qt.html So only a tiny paint repair(?). Harry
Chipped tooth
Post by Chipped tooth » Tue Feb 03, 2015 11:03 am
Thanks Harry, I have seen that but I haven't tried it.
