Time slip and dyno sheet don't match (need advice)
Jdm1027
Post by Jdm1027 » Thu Oct 30, 2014 7:37 pm
Is something wrong with my comb.
Motor made 574 hp and 572 tq on engine dyno. Motor is 418 sb mopar stroker motor. It is in a 72 challenger street car with stock rear suspension, 3.55 gear and a reworked converter from ptc roughly 3800 stall. A competition 727 from tci. Car weighs 3800 with me in it. The best time so far is 7:44 @91 mph in the 1/8. With a 26x10 slick on it. 60 ft times are 1.6. I am looking to try some caltracs on the rear but I just don't feel the mph matches the hp.
Jdm1027
Re: Time slip and dyno sheet don't match (need advice)
Post by Jdm1027 » Fri Oct 31, 2014 11:25 am
I am new to this site is this the place to post such a question??????? Thanks
Dave Koehler
Post by Dave Koehler » Fri Oct 31, 2014 11:39 am
The more knowledgeable will chime in but the numbers they give you are corrected.
Are you running at sea level on a 60 degree day with no humidity? If so then I think you are missing some HP or there is an anchor in the car.
Baprace
Post by Baprace » Fri Oct 31, 2014 12:40 pm
Try this link from Stan Weiss, he has some formulas that help estimate horsepower.
http://users.erols.com/srweiss/calchpm8.htm
Jdm1027
Post by Jdm1027 » Fri Oct 31, 2014 3:39 pm
I ran the nmbers on that site and on wallace calculator and they both estimate about 410 to 425 hp at flywheel. Am i loosing that much power from stock suspension. Shouldnt my mph be up even if my times were slow??
Dave Koehler
Post by Dave Koehler » Fri Oct 31, 2014 3:58 pm
I'll try this again. Check your UNcorrected HP numbers from that dyno sheet. Those are more realistic, particularly if your dyno and your dragstrip are in the same local area.
Jdm1027
Post by Jdm1027 » Fri Oct 31, 2014 5:41 pm
Sorry, All I recieved was corrected numbers on my sheet,
Kevin Johnson
Post by Kevin Johnson » Fri Oct 31, 2014 6:26 pm
Jdm1027 wrote:Sorry, All I recieved was corrected numbers on my sheet,
Josh, is your dyno in Philippi? You can look up the weather on the day you tested there or wherever the dyno is and try to calculate backwards to the uncorrected numbers. Check the elevation and weather at the track as well.
http://www.wunderground.com/weather-for ... lippi.html
thedynoguy
Post by thedynoguy » Sat Nov 01, 2014 10:23 am
just call the dyno shop and get the uncorrected numbers...
John Wallace
Post by John Wallace » Mon Nov 03, 2014 10:06 am
I'd say your MPH matches the ET great. So does the 60'
Now the ET/MPH are for a 465/470 HP engine.
So, you're not using a 100HP somewhere.
Could be as these guys are saying is the weather/dyno numbers are making your HP numbers higher than what you raced at.
If you are at sea level in 70º calm weather when you ran those times, then you should be running faster.
(possibly 6.9's in 1/8th)
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
fdicrasto
Post by fdicrasto » Thu Nov 06, 2014 10:27 am
Did the shop that built the motor also dyno the motor ?
Jdm1027
Post by Jdm1027 » Thu Nov 06, 2014 3:25 pm
Yes sir, I emailed them to get the uncorrected numbers but have not heard from them, He is the one telling me something is wrong with my comb and I should be turning better times. I just thought that with 3:55 in the 1/8 and stock suspension with old worn out air shocks that was what was hurting my times.
Stan Weiss
Post by Stan Weiss » Fri Nov 07, 2014 8:48 am
Can you post a copy of your dyno sheet?
Stan
http://www.erols.com/srweiss/index.html
Jdm1027
Post by Jdm1027 » Fri Nov 07, 2014 9:54 am
Stan Weiss
Post by Stan Weiss » Sat Nov 08, 2014 1:18 am
Jdm1027 wrote:
That is the only information on your dyno sheet?
Stan
