motorbike bottom end
Posted: Sun Jun 19, 2016 5:23 am
Question
I have a four stroke motorbike engine (crankshaft-rod-bearing assembly) and I want to check the clearances
crankshaft end play
big end bearing cage side clearance
crankshaft run out
etc
question is even though it is a four stroke engine (crankshaft-rod-bearing assembly) can I set the clearances up the same as if it was a two stroke engine (crankcase-rod-bearing assembly set up).
clearances I would use will come from a graham bells two stroke performance tuning (onto my four stroke engine).
thanks Steve.
crankshaft end play
crankshaft run out
etc
thanks Steve.
