Superflow 901 radical barometer reading
Funnycar
Post by Funnycar » Sun Nov 27, 2016 10:45 am
Hi
I have a 901 that I am having issues with it uses the ms dos wyndyn when I am making a pull the baro reading starts out stable but as I making the pull it becomes totally radical and moving all over.
I have added more grounds to the frame, block to frame, battery to frame, tried rerouting wires, changed plug wires, changed ignitions, currently have a SBC with a GM hei on the dyno, nothing fancy just to test and see if I can get closer to fixing the problem.
Had a ls motor on the dyno a while back with its own Holley fuel management system. Fuel injected, own coils, etc., seems to me this motor worked fine and had no baro movement.
Any help or suggestions would be appreciated .
MTENGINES
Re: Superflow 901 radical barometer reading
Post by MTENGINES » Sun Nov 27, 2016 8:30 pm
you can force the baro if you have a portable weatherstation. those baro sensors go bad in the console. and when that happens Superflow will tell you to buy a new console. They do not make the baro anymore.
Funnycar
Post by Funnycar » Mon Nov 28, 2016 9:05 am
I will try that and see if that will make it at least stay at a certain setting. But....
We always reset the baro from its default to actual baro but it stays at the time we enter it , I thought it would stay set also, but it does not just goes radical during a pull.
If I could get it to stay set at what we enter yes that would be great .....so unless I am missing a step ...to keep it locked in ....the console still takes over
Zmechanic
Post by Zmechanic » Mon Dec 05, 2016 11:34 am
If you want to try to continue to use the Baro sensor. Get a clamp on ferrite core, and wind the sensor wires through it a few times.
