96 GM passlock system
Engguy
Post by Engguy »
Any one know the proper way to bypass it?
And curious how anyone with an engine dyno can run these newer engines outside the car nowadays.
I don't want to install a remote system I just want it gone.
fast_crew
Post by fast_crew »
you would have to install a resi stor to the passlock circuits. that was the same resistance as the chip in the key or the chip in the lock cyl.
Josh K.
Josh K.
af2
Post by af2 »
10 years ago there was a guy called Larry's electrics in IL. Don't know if he is there but worth a shot!
needforspeed66gt
Post by needforspeed66gt »
Like fastcrew said, measure the resistance of the chip on the key, and install a resistor that falls in the appropriate range...
http://shbox.com/1/vats_bypass.jpg
http://shbox.com/1/pass_key.html
There's schematics on the second page linked that show the pin-outs for the pcm.
Nate @steeldustmachine
Engine Machinist
