It's got nothing to do with J-B Weld.
As soon as I read the article (link) my thoughts went automotive. This technology could be applied to so many things. I figured it'd be worth the read (go ahead - conjure up some of your own applications/uses/research), if you care for this type stuff.
http://news.rpi.edu/update.do
A new method allows a self-assembled molecular nanolayer to become a powerful nanoglue by "hooking" together any two surfaces that normally don't stick well.
When sandwiched between a thin copper film and silica underlayer and exposed to heat, the structure's adhesion strength increases dramatically. The method also allows the nanolayer to withstand temperatures of at least 700 degrees Celsius.
The unprecedented discovery should lead to commercial applications in nano- and microelectronics. Other envisioned uses include coatings for turbines and jet engines, and adhesives for high-heat environments
Photo Credit: Rensselaer/G. Ramanath
Greezer
