I have been running a pressurized cooling system, by modifying the cooling tower to withstand the higher pressures and using a pop-off type valve with a spring set to whatever pressure we want.
It has worked alright, but the spring needs to be replaced often, and I always am nervous when we try the higher pressures like what we run on the racetrack.
So.... After some discussion with Depac Dave it was suggested I try a water bath type system, where we use a standard radiator submerged in water, and control the "bath" temperature with cool water.
I already do something like this with a submerged oil cooler to keep oil temps consistent, so I think it should work, and be pretty painless to build.
Anyone else out there doing something similar?
ryan
Pressurized dyno cooling system
I've done this with both water & oil just like you mentioned, no real problems other then space and thats not a big deal as you can put it across the room if you want to. Tempcontrol takes some work but agian not to hard.
Michael LeFevers
www.mitechengines.com
Lifetime Member of the Bonneville 200 MPH Club
Frist Stock Bodied Car to Exceed 300 MPH
"Aerodynamics are for people who can't build engines" Enzo Ferrari
Go to these guys & get a spring made of the right material to withstand the temps..http://www.centuryspring.com/ or http://www.americanprecspring.com/ or http://www.generalwirespring.com/index.html or http://www.springsfast.com/index.html
Adger Smith
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
903 794 7223 shop
903 824 4924 cell
I agree with Adger. We've done it both ways & while the radiator set-up works fine - there is a bit more service & maintenance involved.Adger Smith wrote:Go to these guys & get a spring made of the right material to withstand the temps..http://www.centuryspring.com/ or http://www.americanprecspring.com/ or http://www.generalwirespring.com/index.html or http://www.springsfast.com/index.html
Mike Laws Performance
