on a chassis that has the torque tube going from the pinion to the transmission, I'd like to remove it and use some swedge tubes and heim joints to set the suspension up like below:
will this work?
will this work
will this work
West Siloam Dispensary
- jmarkaudio
The problem comes with a couple areas. Are the bottom bars parallel? The front would need to be a heim if not, and would be under more load than a true ladder bar. The other is the ability to adjust the front up or down, you may or may not have it in the optimum location for the best launch. Is this a Camaro or Firebird? There are other ways to make them work, or just convert it to a true ladder bar or 4-link.
Mark Whitener
www.racingfuelsystems.com
____
____
it's a vega
I dont mean to butt in here, But SPOHN performance is starting to make parts for the monzas and vegas, theyve already got lower rear control arms, and are working on an adjustable torque arm setup from what I hear.
Im a fan of the torque arm setup....not telling you how to build your car....just some options.
Lotsa guys run REAL fast with the torque arm setup.
God bless
-Shred
Check it out.
http://www.spohn.net/?action=shop&pcid=1376
God bless
-Shred
Check it out.
You should check out the H-body forum. http://forums.h-body.org There are some 10 second cars on the stock torque arm suspension, and atleast one in the 9's. Like Shred said, Spohn has rear lower control arms available now. We at the H body forum are working with Spohn on developing many more suspension parts. Adjustble rear lowers, adjustable torque arms, front adjustable uppers, tubular front lowers (possibly for coil overs), subframe connectors (yes I know, no subframe, unibody, but what else would you call them?). The front control arms will be set up to use S-10 spindles (5 lug/bigger brakes). If you're into Vegas and Monzas that's the forum to go to.
