doing a carb conversion on a 90 FI 5.0 mustang and trying to use the TFI dist instead of a MSD mag dist.
I have the 6al box and retard box wired per instructions.
What & Where do I have to wire the module in the dist to work correctly?
Ford TFI wiring
CC. I can probably print you a diagram if you need it. I'll need an e-mail. dstinerracing@yahoo.com. Dan.
TFI wiring
MSD has all of the wiring diagrams on their web site.
The TFI hook up is an easy one. I believe the red and white wires go to the coil and the orange and black wires go the the coil harness connector.
Good luck
Good luck
