Hard start problem
Hard start problem
Hope someone has some help My camaro footbrake car is hard to start about the 3rd pass-So I went with the biggest interstate battery I could get-trunk mounted-same problem-I changed the solenion on the firewall-still same problem-So I installed a small battery up front-Now works fine-But I don't want to run 2 batteries any Ideas?
Re: Hard start problem
It seems that you might have a big voltage drop? What size (gauge) cable are you running?econo racer wrote:Hope someone has some help My camaro footbrake car is hard to start about the 3rd pass-So I went with the biggest interstate battery I could get-trunk mounted-same problem-I changed the solenion on the firewall-still same problem-So I installed a small battery up front-Now works fine-But I don't want to run 2 batteries any Ideas?
Measure voltage at the starter when cranking. Make sure you have large enough cable both for positive and negative all the way from battery to starter. 2/0 is enough. Check all grounds and all connections.
- jmarkaudio
X2. Run large gauge welding cable for both, too many people rely on the chassis for a ground. Bad idea.Keith Morganstein wrote:It seems that you might have a big voltage drop? What size (gauge) cable are you running?econo racer wrote:Hope someone has some help My camaro footbrake car is hard to start about the 3rd pass-So I went with the biggest interstate battery I could get-trunk mounted-same problem-I changed the solenion on the firewall-still same problem-So I installed a small battery up front-Now works fine-But I don't want to run 2 batteries any Ideas?
Mark Whitener
www.racingfuelsystems.com
____
____
I think the cable is #2 -I only have a big groung strap going to the frame from the battery. I sanded it good too-It does have a bad voltage drop-Why do I have to have a ground running from the starter to the battery? The engine also has a ground strap going to the frame. Thank you for trying to help me
- af2
Double 0 is the least I run on front or rear battery and never have problems. #2 is tiny compared. The guys that responded are right on!econo racer wrote:I think the cable is #2 -I only have a big groung strap going to the frame from the battery. I sanded it good too-It does have a bad voltage drop-Why do I have to have a ground running from the starter to the battery? The engine also has a ground strap going to the frame. Thank you for trying to help me
GURU is only a name.
Voltage Drop
You should have a good ground all the way from the negative battery terminal to the starter if at all possible since the various components that make up the car, chassis , engine , transmission are poor conductors compared to copper.
Also the best way to check for voltage drop on the ground side of the starting circuit is to place your voltmeter between the starter housing and the negative terminal. If you read 2 volts while cranking then you have a loss of 2 volts in that circuit,You can continue to work your way back toward the battery to isolate the drop to the particular portion of the ground circuit. Say you place the meter between the starter and the front of the frame if you have say 1.8 volts then you can be assured that your motors chassis ground is where most of the voltage drop is occuring. I mention this because if you have a poor ground at the motor frame junction it can cause all sorts of problems, some times a poor ground on a motor (on a more or less stock car with multiple grounds) can cause the transmission to act as the ground for the starter in this case the current will be flowing through the trans or engine bearings.
That is why it is always advisable to run a separate ground wire to the starter (Or as close to the starter as possible ) as well as to a ground block. On a race car use the ground block to ground the electronics of the car ( many computer components are very sensitive to using a chassis ground ).
Best of luck .
Best of luck .
- af2
What Dave was saying is turn it over a few times then hit ignition for start!econo racer wrote:Yrs ago I ran a tilton type starter and it never did this until I went with a new stock type starter-My compression is only 10.1 if that
WOW! how can a person disappear from forums? Dave's fuel injection is above the rest.
