Offenhauser 360* Equaflow
cjperformance
Post by cjperformance »
Hi, does anyone have an "Offenhauser 360degree Equaflow" intake manifold to suit a Ford 351 Cleveland that they want to sell???
Thanks, craig.
enigma57
Re: Offenhauser 360* Equaflow
Post by enigma57 »
Craig, I found this listing on the H.A.M.B......
http://www.jalopyjournal.com/forum/show ... p?t=510142
This intake is used and is for a 351 with large port 4bbl heads. Ad says its solid but needs some cleanup. He is asking $175.00 US.
Found some listings for new Offenhauser 351 intakes here for both 2bbl and 4bbl heads (Offy still make many of them off the old molds)......
http://www.offyparts.com/index.php/cPat ... /2a/page/2
Charlie Price over at Vintage Speed is an Offy dealer. He does not list all available on his website, but you might give him a holler. He may be able to order you one directly and beat the prices in the above link. At the bottom of this page, you will find contact info with E-mail and phone number. Also a link to his online catalogue......
http://www.vintagespeed.com/
Also know of a 351 Weber IDA downdraught setup for large port 4bbl heads. Kinda pricey, but nice if he still has it. He installed 2bbl heads having smaller ports for better low end torque in everyday driving and that is why he pulled the Weber setup. The carbs are the later model IDAs made in Spain, not the originals made in Italy before the factory was moved. But on balance, they are newer and have little wear.
Hope this helps,
Harry
cjperformance
Hi thanks for the info. Im after the Offy 360 as I modify them to become a low rise dual 4 barrel intake and use them with 2 x 4 bl lpg carburettors. They work very well for this application, they are nice and flat on the top which makes the mods easy and reliable.
Thanks,,
enigma57
Post by enigma57 »
Glad to be of assistance, Craig. Hope this gives you some leads.
In the Offy 360 degree intakes, I have only 1 here and it is for a small block Chevy.
Wish you luck on your hunt for the 351 Ford version.
Best regards,
Harry
Keith Morganstein
Post by Keith Morganstein »
cjperformance
Keith Morganstein wrote:This one?
http://www.summitracing.com/parts/OFY-5964/
Thats the one thanks Keith. Cant believe I did not do a summit, etc etc search!! :roll:
Thanks to all for the links, very helpfull.
