Have Dart Little M Pro Series Block small block 400 that has been fully machined, balanced, and blueprinted. Block is now 406 and has a Custom Forged steel crank that cost $1000 in 2008. No internals but the crank. The motor was only ran a few times on a dyno and made a over 500 hp. Machine work cost around $1500. The setup is really like brand new and total cost to get block, crank, and machining done would cost close to or more than $6000. I just don't have the time and money with other projects going on to keep it. Will send more pics on request. Email cwmartin27@gmail or call 270-564-1963 MUST SELL, $2250 obo!
AD from Summit Racing- True high performance blocks - $3,535.95 Bare Block only
Dart's Little M Pro Series Bare Blocks are designed from the ground up as true high performance blocks that can be used with standard off-the-shelf small block components. These blocks are cast from premium high-strength iron and beefed up in all of the critical areas. With a standard deck height, extra-thick cylinder walls, and a competition oiling system, the Little Ms are the perfect starting point for a powerful and reliable engine for the street or the race track. These Pro Series blocks add special racing-oriented features, which were previously only available as costly custom work from specialized machined shops. They include a cam upgrade to 50mm and block lightening options.
Main Journal Type 400 mains
Engine Block Style Aftermarket
Deck Height (in) 9.025 in.
Cylinder Bore as Shipped 4.125 in. *(Bored to 406)
Maximum Cylinder Bore Diameter 4.185 in.
Engine Block Material Cast iron
Engine Block Weight (lbs) 205 lbs.
Main Bolt Style 4-bolt
Main Caps Included Yes
Main Cap Material Steel billet
Main Cap Fasteners Included Yes
Main Bearings Included No
Rear Main Seal Style 2-piece
Finished Cylinder Bores No *(All machine work had been completed)
Raised Cam Location No
Cam Bearings Included Yes
Freeze Plugs Included Yes
*Notes Lightened block
Dart Little M Pro Series Block small block 400 w/crank
