Custom 427 SBC 18 degree top end best of everything
CNC BLOCKS
Post by CNC BLOCKS »
I have a 427 SBC all brand new parts that we are selling as the customer has some health issues going ond needs to sell everything off.
We have a Top end package that http://www.3vperformance.com/ has that includes a set of custom oval port 18 degree Brodix castings custom port by Tom, ty valves, custom intake to match heads, carb. that was built by Tom for this build. 1.85 crower stainless shaft rockers. Brodix H-13 custom head studs. The cam is a 50MM roller set up that has been spintron tested and its at .850 lift range.
The short block is a Iron Eagle block with a 50MM roller cam bearings, 9.000 deck height, 4.185 bore, pistons were designed by http://www.3vperformance.com/ and built by CP pistons, Custom ring pack, Dragon Slayer crank 3.875 stroke, Callies 6 inch ultra rods assembley is all balanced. Included is a Jesel belt drive. Steffs aluminum wet sump pan with pick up. block has been machine for oil returns in the lifter galley area.
This engine has the best of everything and we are asking 24600.00
http://www.3vperformance.com/ has this figured to be right at 850 to 900 horse. For drag racing only
Thanks for looking Carl
Website is up and running
Machine shop tour
Monthly Specials
