Engine Fiat Tipo 1,6
V12
Post by V12 » Sat Nov 26, 2011 4:37 am
For Sale complete engine -NEW like on photos
all lightened parts , ally pulleys with new water pump
Racing head 21-4 N valves 7mm 40/35 heads ,bronze guides
11,2:1 statis comp , can be installed racing cam /top flat lifters
new cam box , with engine go set reserve head bolts,flywheel bolts
crank fixing bolts
afrika blok.JPG (123.09 KiB) Viewed 13640 times
V12
Re: Engine Fiat Tipo 1,6
Post by V12 » Sat Nov 26, 2011 4:49 am
photos
glava afrika.JPG (107.4 KiB) Viewed 13639 times
V12
Post by V12 » Sat Nov 26, 2011 4:50 am
water set
V12
Post by V12 » Sat Nov 26, 2011 7:23 am
P2
V12
Post by V12 » Sat Nov 26, 2011 7:25 am
P3
V12
Post by V12 » Sat Nov 26, 2011 7:27 am
P33
V12
Post by V12 » Wed Nov 30, 2011 9:33 am
1,6 SOHC is same like all SOHC engines what is installed in Fiat 128 , X1-9 , ritmo,uno ....and in Europa is lightest way to installed stronger engine in 128 or x109
V12
Post by V12 » Fri Dec 02, 2011 1:49 pm
4.
V12
Post by V12 » Sun Dec 18, 2011 11:55 am
V12 wrote:For Sale complete engine -NEW like on photos
crank fixing bolts
Complete engine with new cam box, new lifters new racing cam installed with cam belt installed on , new slide throat body 40mm with engine , new Magneti Marelli distributor ,200mm 1,6 lightened balanced flywheel
with delivery to all world DHL cargo -4900 euro
V12
Post by V12 » Sun Dec 18, 2011 12:03 pm
slide throat photo and el. distributor
V12
Post by V12 » Thu Jan 05, 2012 4:00 pm
set racing valves 6mm -40/35mm .....
V12
Post by V12 » Fri Jan 20, 2012 1:49 pm
Titanium retainers for 6, 7 and 8 mm vale steam - Isky springs
V12
Post by V12 » Fri Mar 02, 2012 4:24 am
Complete new engine all parts lightened balanced with 40/35mm valves 7mm steam , racing cam 324* 11,3mm lift ....
raceman14
Post by raceman14 » Wed Mar 07, 2012 4:07 pm
You did a great job on the engine, I have built a couple of these in X-19, and many of the 1.8 and 2.0 DOHC engines. They are basically a Ferrari V-8 cut in half, and man do they turn the RPM's.
What is the sale price in EU or USD?
Thanks,
Mark
More is always better!!! Most of the time.
V12
Post by V12 » Thu Apr 05, 2012 5:43 pm
LSD for Fiat 128, x1-9 , yugo tripod half shaft bearings
