1986 Camaro
vortecpro
1986 Camaro
Post by vortecpro » Sat Nov 29, 2014 11:47 pm
1986 Camaro, clean small tire car you can drive to the track, runs 10 teens @ 130, 377 small block, 5 passes since built, turbo 350, muffled up.
11000.00.
vortecpro
Re: 1986 Camaro
Post by vortecpro » Sun Jan 18, 2015 8:38 pm
vortecpro wrote:1986 Z/28 Camaro, clean small tire car you can drive to the track, runs 10 teens @ 130 plus mph, 377 small block, 5 passes since built, turbo 350, muffled up.
13,000.
Some pictures, 377 has: Dart heads, T&D shaft rockers, Cola crank, SRP pistons, A-1 converter, dynoed @ 604 HP @ 7200 RPM, has 9 sec potential. Full interior.
Ratman
Re: 1986 Camaro
Post by Ratman » Mon Jan 19, 2015 10:05 am
Nice looking Camaro
Enigma
Re: 1986 Camaro
Post by Enigma » Sun Jan 25, 2015 4:20 am
Do you have any more info on the car, Mark? Suspension, trans,convertor, gearing, compression, roll bar, how drivable is it? Things like that. Very nice looking ride. Any under hood pics?
vortecpro
Re: 1986 Camaro
Post by vortecpro » Sun Jan 25, 2015 8:24 am
Enigma wrote:Do you have any more info on the car, Mark? Suspension, trans,convertor, gearing, compression, roll bar, how drivable is it? Things like that. Very nice looking ride. Any under hood pics?
Suspension, 8.5 10 bolt, welded tubes, MW axels, spool, blanchered ground plate between the diff and cast cover, heimed TQ arm adjustable moly bar, 4.56 gear. Comp 12.1, cam 270 @ .050, 604.9 dyno tested HP, moly 6 point cage with full factory interior, B&M shifter in console. Trans std weight Turbo 350 with sprag and shift kit, A-1 8 inch converter. Magna fuel 500 pump with regulator, sumped gas tank with vent. Drives tight with great brakes, very clean car with fresh paint 5 passes since built. It is supposed to be sold as of last week, but I have not seen the money yet, If the sale falls through I will get it down from the lift and take good detailed pictures and post them. Thanks.
eddie
Re: 1986 Camaro
Post by eddie » Thu Mar 23, 2017 2:03 pm
is the camaro still available
