Shop Clearance Sale! All Parts Must Go!
FastBuick
Post by FastBuick »
Items For Sale:
SSRE Dart Big Chief Spread Port BBC Intake Manifold Fully Ported by Scott Shafiroff Racing Engines part#43124000 $650
Holley 650 Double Pump Carb part# 0-4777S $200
Transmission Specialties Super 8 (9") Racing Torque Converter $575
Hooker Headers BBC Racing Headers for Altered, Roadster, Dragster, Chassis Car, etc. with EVAC system $300
Brand New Titan Speed Engineering Pro Series Billet Aluminum Single Stage External Oil Pump $725
Brand New Titan Speed Engineering Labyrinth High Performance Billet Aluminum Oil/Fuel Filter $275
Brand New Titan Speed Engineering Pro Series Billet Aluminum Single Stage External Oil Pump and Titan Speed Engineering Labyrinth High Performance Billet Aluminum Oil/Fuel Filter *PACKAGE DEAL* $950
Brand New Lunati BBC Solid Flat Tappet Camshaft
Part# 30110924
Advertised Duration (Int/Exh) 288/298
Duration @ .050" (Int/Exh) 249/259
Gross Valve Lift (Int/Exh) .615/.620
Lobe Separation Angle 110
Intake Center Line 108
Valve Lash (Int/Exh) .020"/.022"
$150
TCI Powerglide Manual Transbrake valve body $225
Jesel SBC Belt part#30990 $25
Jesel BBC belts part# 31010 5 available $25 each
JE 52 Series Wrist Pins SBC .927"x2.750" part# 927-2750-15-52S $50
JE 52 series wrist pins BBC .990"x2.930" $50
PAC Racing Valve Springs part# PAC-1356 complete matched set of 16
Outer Spring Diameter 1.500"
Installed 300# @ 2.100"
Open 1002# @ 1.200"
Coil Bind 1.130"
Rate 780 lbs./in.
$175
Comp Cams Titanium Valve Spring Retainers for Triple Springs. $125
GM Performance Parts
Part#
14088783 Timing Chain $25
12371041 Pushrod Kit $25
If you have any questions, want more information, or would like some pictures please contact me. You can contact me by calling or texting me at 570-510-2811 or PM me here.
Let's make a deal! All prices are negotiable. Make offers if interested. And if you buy multiple items I can sweeten the deal more.
I do accept PayPal and most other forms of payment including credit cards.
Thanks
PAC Racing Springs Authorized Dealer
Independent T-1 Certified Amsoil Dealer
Wix Filters Dealer
FastBuick
Re: Shop Clearance Sale! All Parts Must Go!
Post by FastBuick »
Jesel SBC Belt part# 30990 is SOLD.
Thanks
Wix Filters Dealer
Jeff Lee
Post by Jeff Lee »
What screen is included?
I sent you a text also. Please text me a picture.
Thanks.
NHRA SS/G
1970 AMC AMX - 390 4-speed
FastBuick
Post by FastBuick »
The screens that are with it are for use with oil. I will gladly send you pictures. I didn't receive a text though. Did you send it to the right phone number or maybe did it not send? My number is 570-510-2811.
Thanks
Wix Filters Dealer
Jeff Lee
Post by Jeff Lee »
Oops! I sent it to 2812.
Just resent to 2811.
Thanks
NHRA SS/G
FastBuick
Post by FastBuick »
Parts added For Sale:
Comp Cams Custom Solid Roller Camshaft
314/328 Adv. Duration
281/290 Duration @ .050"
.471/.451 Lobe Lift
.706/.676 Gross lift with 1.5 rocker
.754/.722 Gross lift with 1.6 rocker
.800/.765 Gross lift with 1.7 rocker
108 Lobe Separation
$60
J.W. Performance Transmissions High Volume Powerglide front pump assembly. Part# 10786 with other half of the pump and completely assembled. $225
TCI Hardened Input Shaft made from Vaccu Melt 300 aircraft quality billet steel for Powerglide and has turbo converter splines part# 749600 $85
TCI High Quality Stress Proof Steel Clutch Hub part# 748300 $30
Manley Performance ARP 2000 Rod Bolts part# 42390-4 (8 packs of 4 are available, or 2 complete sets of 16) $12.50 per box of 4 or $50 per set of 16
Wix Filters Dealer
FastBuick
Post by FastBuick »
Transmission Specialties Super 8 torque converter is Sold. Thank you.
Wix Filters Dealer
FastBuick
Post by FastBuick »
TCI Powerglide Manual Transbrake Valve Body is Sold. Thank you
Wix Filters Dealer
