Pro built Road Race dry sump LS6 for sale
Posted: Sat Feb 20, 2016 9:33 am
Dry Sump Road Race LS6 built by Schwanke Racing Engines
* Forged Mahle pistons
* Eagle H beam 6.125 rods
* GM LS6 crank
* ARP rod bolts
* fresh 243 heads with ISKY 165 A valve spring
* Comp Cams rocker trunion upgrade
* Cloyes timing chain
* upgraded push rods
* ATI damper
* ISKY 280/290 cam
* Moroso dry sump pan
* Barnes single stage dry sump scavenge pump, this system uses the stock type pump for pressure.
* LS6 intake and throttle body
* ASA series ECU and custom tuning and harness by Schwanke
Complete motor with all front drive and power steering... ready to run
bottom end had about 10 hours time SCCA Club racing. I had the heads freshened and bottom end checked and had motor dyno'd at Byron Koury Racing Engines in Deland Fl. Motor made about 460 HP and 430 torque
Excellent, torque motor for road racing, solo, pro street etc.
New from Schwanke this motor is 14K
Sell for 7000
Locate in Deland Fl, near Daytona Beach
"Bosco" at Bosco022022 at yahoo dot com or three eight six 717*0745
* GM LS6 crank
* ARP rod bolts
* ATI damper
* ISKY 280/290 cam
Sell for 7000
