Garage shop clean out
Adger Smith
Post by Adger Smith » Mon Feb 22, 2016 4:57 am
1. 1 ea used 12” wide by 15 5 ½ BS Monocoque lite weight alum wheel This is the style that has the round holes with the back covered with the back shell Multi bolt pattern. Make offer
2. <NEW> set of “New” Brodix –5 Raised runner BBC heads CNC & hand polished These are some of the largest port volume and flow of conventional 23 deg BB heads
2.350 x 1.88 Brodix SS In & Ex valves Complete with Sonny’s Brodix
Dominator flanged Intake fits std 9.780 deck block.
Complete set up Intake & heads $4200.
3. <NEW> set RHS Pro Elite #11038 CNC Ported 379 CC ports Milled to 118 CC chambers
with 2.300 X 1.88 stainless valves. Set up with Pac .850 springs and Pac Ti retainers. 10 degree locks and seals with spring cups. These heads and parts are ALL NEW they also have my hand porting/CNC clean up. $3750
4. Strange 9” Ford Pro Nodular third member (older HD N style) Part # PRF115 w/ 4.86 9310 gears Forged Alum bearing support Lt lwt. 40 spline steel spool ARP bolts assy by Strange Chrome Moly 1350 yoke with 35 spline pinion Very low time, less than 10 passes $950.
5. Chevy SB LT1 Reverse cooling block (stock) Std bore vat cleaned and checked for cracks w/ factory rods and a std cast 1 piece seal crank (good for grinding +.013 stroke) also a used cam drive water pump “New” LT1 reverse cooling heads w/valves and stock springs This LT1 was bought for a stocker project that didn’t happen. Sold as a package only $ 1000
6. <New> BB Chevy STD bore "286" casting 4 bolt block (D-26-0 date code) I have done a fresh line hone and 4 bolt ARP main studs. I surfaced (wet grinder) the deck to 9.780 w/ BHJ plate system. No CB or FP. No hard block in water jackets. Vat cleaned No flaws & Ready to put bore to your size. $850.
7. <NEW> Probe 427 + .060 Max compression BBC pistons and Speed Pro ring set Light weight PPPC tool steel pins, Skirt and dome coatings $ 750
Other Pictures of all other listings are available on request.
Buyer pays actual freight on all sales. I do have discounts with Fed Ex.
Adger Smith
Adger Smith Performance Engines Texarkana Tx
adgersperf@aol.com
Text 903 824 4924
Adger Smith
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
