Dart sbc block, speier heads, compstar crank/rods
Posted: Mon Mar 14, 2016 1:11 pm
Parts located near pittsburgh pa
Dart SHP 2 pc seal 4.125 bore 350 main block. Back from machine shop, cleaned and checked for cracks/etc. Fresh line bored to fix some cap walk fretting. Still has some marks in mating surface of caps but not a problem. Arp main studs. I do have head studs as well for $50 more. Bearing bore is in spec. Will need bored over atleast .020" to clean up minor nicks in bore. Been 9.00" decked. 800$ picked up. Do not want to ship but may be able to work something out. Also have canton oil pan and pickup and melling performance oil pump for 150$ more
Speier racing heads v2.72 245cc heads. 2.1" intake 1.6" exhaust valves. Hyd roller springs PAC 1300 series spring with titanium retainer. Good to .650". 190 lb seat 450 open. Pushrod pinch welded and clearanced for 3/8" pushrod. Minor dimpling on few chamber quench pads where piece of turbo blade went thru but pose no problem. Head had valveseats fixed and rejobbed. Decked slightly which took out some of the dimples but not all. Fresh from machine shop
Include LGM shaft rocker system 1.6 rockers. 2000$ + ship obo
Compstar callies crank 3.75 stroke, 2 pc rear main. Slight runout on center main, .003" but can be used. Journals are standard but need or should be polished before running. 300$ obo + ship
Compstar sbc rods. H beam 6.00". Needs new bushings at the wrist pin end which will be 100-125$ of machine shop labor. Big end is slightly out of round but can be used according to shop. Just checked at machine shop, have paper work. 250$+ shipping.
These parts held my 1200+ hp twin turbo build, but i would not attempt that again. Good parts for na motor or mild power adder
Message for pics. Parts are cleaned and ready to be sent to machine shop for final prep.
