NOS UltraDyne Custom Ground Solid Lifter Cam & Lifters, SBC
enigma57
Post by enigma57 » Sat Mar 19, 2016 7:50 am
$235 - New UltraDyne custom flat tappet solid lifter cam and lifters for small block Chevy. New in box. Never installed. Similar duration to Duntov 30-30 cam with higher lift and tighter LSA. Reduced base circle to clear 3.75" stroke 383 or 400 crank. Ground by Harold Brookshire when he had UltraDyne up and running.
If interested, please send PM. I am located NW of Houston, Texas.
Will ship parts and split shipping cost within lower 48 states...... Payment by US Postal Money Order accepted.
If picking up parts locally, cash on receipt...... No checks, MOs nor credit cards if picking up locally.
All sales are final......
Specs...... 252 degrees duration @ 0.050" lift intake and exhaust, 0.525" lift, ground on 110 degree LSA, reduced base circle of 1.10" for clearance with 3.75" stroke 383 or 400 crank, ground on Pro-55 core.
Best regards and thanks for your interest,
Harry
Ks Fats
Re: NOS UltraDyne Custom Ground Solid Lifter Cam & Lifters,
Post by Ks Fats » Mon Mar 21, 2016 5:09 pm
P.M. sent Harry.
enigma57
Post by enigma57 » Tue Mar 22, 2016 6:52 am
Mike, Harold said to set valve lash (both intake and exhaust) at 0.026" hot (if running cast-iron block and aluminum heads, 0.022" cold for initial setting).
I had UltraDyne custom ground my solid lifter flat tappet cam with the following specs for mainly street / highway use...... 252 / 252 degrees duration @ 0.050 " lift and 0.525" / 0.525" total lift for both intake and exhaust. Cam is ground on 110 degree LSA using Pro55 core for extended life and reduced base circle of 1.100". Seat duration @ 0.020" lift is 285 deg. for both intake and exhaust. Overlap is 65 degrees. Harold said to degree intake lobe to 104 deg. intake closing angle ATDC. UltraDyne solid lifters have EDM oiling holes in center. Seat Timing from cam card is as follows....
Grind number: SB285/285 F10
Serial number: J5005
Duration @ 0.050" - 252 intake, 252 exhaust
Lobe Lift - 0.350" intake, 0.350" exhaust
Lobe Separation - 110 degrees
Seat Duration @ 0.020" - 285 degrees intake, 285 degrees exhaust
Gross Valve Lift (1.5:1 Rockers) - 0.525" intake, 0.525" exhaust
Valve Lash (Hot) - 0.026" intake
Degree Intake Lobe To - 104 degrees ATDC
Seat Timing, Intake - 38 degrees BTDC / 67 degrees ABDC / 104 degrees
Seat Timing, Exhaust - 78 degrees BBDC / 27 degrees ATDC / 116 degrees
Overlap - 65 degrees
Thanks for your interest,
Harry
enigma57
Post by enigma57 » Tue Mar 22, 2016 6:39 pm
Cam and lifters are sold pending receipt of payment.
Thanks,
Harry
