A. 1 ProFlo 2 system semi complete
Intake, 4 bbl throttle body w/iac, fuel rail, injectors, ecu, partial harness, some sensors, control pad. Fits Vortec heads $1200 +shipping
Sells for $3000 plus new
B. 1 Performer Proflo (early system)
intake (low sinlge plane), 750cfm 2bbl throttle body w/iac, fuel rails, injectors, ecu, control pad, partial harness, some sensors, pressure regulator. This system also comes with a high rise single plane intake that fits the 2 bbl throttle body that is brand new. Fits conventional sbc
$1200 plus shipping. Sold for $3000 plus new
I may have a wide band for both as well. Pics are samples to show the intakes, will add real ones asap.
[attachment=1]CH20377-lrg.jpg[/attachment]
[attachment=0]edl-35000_w.jpg[/attachment]
Located In southern Illinois/St. Louis area
618-304-8453
Steve
Edelbrock Pro Flo systems
Re: Edelbrock Pro Flo systems
[attachment=0]IMG_0950.JPG[/attachment]
Here is the high rise single plane. I actually think it goes with the Proflow 2
The 2bbl system is sold. I also found out that the 4bbl system is a Pro flow 1 and Edelbrock still supports it.
What I have left:
2 intakes- one vortec and the other is conventional sbc
ecu and controller
4bbl throttle body
fuel rails and injectors
harness
Wide band with gauge- Innovate
What I have left:
ecu and controller
4bbl throttle body
harness
