454 2pc Block 4 sale
Posted: Wed May 04, 2016 10:06 am
Have a Fresh 454 +.070 bore block for sale [Sorry Adger-wrong casting #] Block was Baked and Blasted. Pressure tested-Passed. Block was Short Poured 1 1/2 up before being clearanced for Min of 4 1/2 stroke. Deck was BHJ d to 9.785-end rails milled .060. [Also drilled the addl. water passage holes in deck per MLS gasket-called spark plug cooling holes] Bores were done off BHJ and bored to 4.315. Plate honed with Bolts and MLS gasket to 4.320/+.0005/-.0000. This is a 2 bolt block that has 3 Steel Caps [#2-3-4 position] installed. A new Set of ARP main bolts included. The block was line bored-3 Steel Caps and Block was Line honed. 2.9373-2.9376. Oil pump was on with ARP stud when line honed. Needs final wash and cam Brgs installed. 750.00 is the price. Location is North Cental Ohio. 44052 Zip Code
