sb2.2 and manowar block
Posted: Sun Oct 23, 2016 1:15 am
Ford Man-O-War block
4.175" bore
.937 bushed lifters
60mm babbit cam bearings
Billet main caps 2.250
Broke a rod and damaged 2 cyllenders that have been repaird and ready for a sleeves from previous owner
Needs a crack welded on top of deck
900$
I need you email or phone nr for pics
Sb2.2 Block
184 Casting Block
4.185" bore
Deck height at around 8.995
55mm roller cam bearing tunnel
Small journal main bearing
.937 Keyed Bronze bushing lifters
2 Sleeves done by Charlie Weston ín NJ
Has flat tapped oiling jets
New ARP main beating studs
Dry Sump Block
Closed cam bearing tunnel inserts included
Asking 1500$ OBO
If you want a pictures i need your email or phone number
4.175" bore
.937 bushed lifters
900$
Sb2.2 Block
184 Casting Block
4.185" bore
Dry Sump Block
Asking 1500$ OBO
