Legal NHRA Topsportsman
Posted: Thu Feb 09, 2017 9:07 am
92 Camaro Legal NHRA Top Sportsman, Chrome Molly Chassis, NHRA cert to 6.0 June of 2016 till 2019.All SFI certs good untill 2018,Complete MW 9" rear end with 4:30 Pro gears.Penske coil overs built by Chris Bell.Car Built by Gateway Race Cars, Paint by Hipster Race Cars and Flames by Stacy's Design Race Car Graphics, weights 2380 with 200 lb driver and 2 fuel tanks(front and rear).Magnafuel Prostar 500 Fuel Pump and Filter. On board Fire system,Pro Comp Oil, Fuel and Water guages and 11,000 RPM Tell Tale Tach and shift Light.Hurst Quarter Stik with Co2 Shifter and tank,MSD 7AL3, Painless switches, Mega 450 Box,Strange Struts and front disc, Wilwood rear disc,Line Lok,Spring launch Chute1 1/4" chrome Molly wheelie bars,Chrome Molly Driveshaft and tunnel,Aluminum rad and twin fans,Hoosier 17X15 on rear with 70% left, Good Year 26X4.5 on front with 80% left.All Aluminum 582, Dart Block, 14:5 to1 comp,Profiler 365CNC heads, Titanium valves, retainers and Keepers,New Manley Springs, good for 1" lift, installed 380 on seat,1020 open, 1.7 and 1.8 T&D Shaft Rockers, Profiler Sniper intake matched to heads and reworked 2 and 7 port so they will not run lean at high rpm.Manton 7/16", .166 wall push rods, Reher Morrison 420-116 camshaft, Isky bushed Roller Lifters, 6 stage Autoverdi dry sump pump and Moroso oil pan,Peterson Oil Tank, New Diaper on pan, JW Flywheel, MSD Crank Trigger,MSD low profile dist.Msd wires, 3 HP starter, 2 3/8" Headers, Meziere waterpump. ATI Tranny with external cooling pump, Abruzzi 9" Converter, 1:80 straight cut gears, 7clutch high drum,Aluminum Rad with twin fans, I'm missing a bunch of stuff.You need to see this car, I will pick you up at the airport .$31,000 Turn Key with spares "DELIVERED",Car went 7:86@176 at Division 1 qualifier on C-12, Bad Back have to quit, My loss is your gain, phone 813-702-4934 for more info. I have pics, e-mail: mackie7920@brighthouse.com
