Looking for a Sedri 57 tool holder
kkustomz
Post by kkustomz » Fri Oct 14, 2016 12:56 pm
I am looking for a #57 tool holder that is used for holding counterbore cutters. This is not the same as the tool holder used for multi angle seat work. Looking to see if there are any good used ones out there before I buy new.
Here is a link to it on Serdi's website
http://www.serdimachines.com/catalog/in ... 20S57%20MC
Thanks, Keith
PackardV8
Re: Looking for a Sedri 57 tool holder
Post by PackardV8 » Fri Oct 14, 2016 1:37 pm
Don Dennis
(425) 766-1619
sometimes has loose tooling available.
buck
Post by buck » Tue Oct 18, 2016 2:45 am
The serdi milling heads fit on the standard 5100 holder. All you need is a small shim to go on the flat for locking the set screws down. Buying another tool is unnecessary.
BMR @ Facebook
kkustomz
Post by kkustomz » Sun Oct 23, 2016 10:36 pm
Do you mean two pieces that would look almost like a woodruff key cut in half? The set screws hit dead center on the edge of a standard holder and I would prefer to not to retighten the set screws after each seat like I have been doing. Thanks
ProPower engines
Post by ProPower engines » Tue Oct 25, 2016 1:18 am
Sound like there is an underlying vibration issue you need to solve. Unless the tool holder you have now do not fit the ball driver tight enough.
If you are using a small tool holder and are running out of pilot room use a shorter bounce spring and use a spacer with a notch cut in 1 side to allow the cutter to miss the spring. the other option with small valve heads with limited chamber clearance is an off set cutter. I get them from Newen or they can be had from Goodson in the HP cutter section. They are limited in selection but if you have the basic blueprint of the cutter send it to Pascal at Newen and they can supply something the same of similar for your needs
