Any "new and improved" spirolox tools?
PackardV8
Post by PackardV8 » Tue Nov 22, 2016 1:45 pm
Since Studebaker and Packard pistons don't usually come with spirolox, I seldom deal with these. Somehow, a 496" BBC snuck in and my machinist will have to install spirolox. Looking for whatever's best today, as he's already bitchin' about ruining his fingers.
FLYIN FINN
Re: Any "new and improved" spirolox tools?
Post by FLYIN FINN » Tue Nov 22, 2016 10:12 pm
Stretch them out a bit like a spring and use a small screwdriver and slide em right in
bill jones
Post by bill jones » Tue Nov 22, 2016 10:49 pm
simple way to install them is to stretch'm all out first--then just roll'm in
spirol locks stretched out.jpg (46.4 KiB) Viewed 2108 times
-I take a small screwsdriver and modify the tip like this---to get in under the little end of the spirol lock to work that end out---but also use it to push the spirol locks in.
thin edge is prone to break off.jpg (29.84 KiB) Viewed 2108 times
ec1
Post by ec1 » Fri Nov 25, 2016 11:53 am
I've always been the wiz at installing spirolox, most are with some practice. I tried a customer supplied "fancy install tool" and it was a joke. Just do the technique as above.
wagspe208
Post by wagspe208 » Fri Nov 25, 2016 11:28 pm
WOW.... don't take all the advice you see on here.
Whew.
Wags
gofaster
Post by gofaster » Sat Nov 26, 2016 12:00 pm
I'm not sure that stretching them out like the above photo in the earlier post is good or bad.
I like to put the Spirolock on my finger and push the first lap out just far enough to get it started in the groove with my fingernail, then follow it around with a blunted scribe tool.
If this is new to you, practice on an old piston.
Once you get the knack it's really easy.
Jim McMahon
Heads1st
http://www.heads1st.com/
