LED shop lights
Heat/AC, electrical, lighting, flooring, design, construction, photos...
groberts101
Re: LED shop lights
Post by groberts101 » Sun Apr 22, 2018 2:11 pm
psychomotors wrote:
Sat Apr 21, 2018 2:34 pm
groberts101 wrote:
Thu Mar 22, 2018 9:39 am
Old thread I guess but Menards now carries 8ft hardwired LED's. Waited for the 11% off deal and got 8 of them. Think they're 5K spectrum and very nice for $80 each. great investment for any shop.. wish I'd have done it sooner!
Went yesterday to our local Menards. They had the 8' footers but you have to use a "intastart" ballast. So , I dig though all their ballasts to find one and they had none for the required 75 watt bulbs. I left empty handed.
These are the one's I bought. Doubled them up side by side with a little spacer(used 1/2" nuts) to permit cover removal. Turn key stuff.. just replaces your old housing completely.
https://www.menards.com/main/lighting-c ... 7&ipos=137
psychomotors
Re: LED shop lights
Post by psychomotors » Thu Apr 26, 2018 1:43 pm
I was looking at the plain bulbs @ $19.99 a pair. I already have two 8' fixtures and just wanted to convert.
Kevin Johnson
Re: LED shop lights
Post by Kevin Johnson » Sat Apr 28, 2018 8:17 pm
If you need another reason to switch over, when the county inspected my shop the three things I was immediately asked about were: 1) Solvents and their disposal; 2) Furnaces of any type; 3) Fluorescent light bulbs. They wanted receipts showing that the bulbs were disposed of properly.
77cruiser
Re: LED shop lights
Post by 77cruiser » Wed May 02, 2018 10:37 am
They all broke so I through em in the garbage. Probably not the right answer. :D
Jim
exhaustgases
Re: LED shop lights
Post by exhaustgases » Wed May 30, 2018 1:38 pm
I like LED but, if you check it out the light from them is bad. I wish there was a spray that would knock down the blue light that they emit. Any ideas?
lefty o
Re: LED shop lights
Post by lefty o » Thu May 31, 2018 10:44 pm
you just have to look at what your buying, they come in all color spectrums, from bright white to piss yellow.
resurrectionjoe
Re: LED shop lights
Post by resurrectionjoe » Fri Jun 01, 2018 12:03 pm
I have 5000K lights in my shop and they do not have any blue tint.
5000K or below is what your looking for in my opinion.
lefty o
Re: LED shop lights
Post by lefty o » Sat Jun 02, 2018 10:50 pm
4500-5000k really seem to be the sweet spot for bright white light.
exhaustgases
Re: LED shop lights
Post by exhaustgases » Wed Jun 06, 2018 2:25 am
Yes but unless its a true filter I still think the blue light is present.
https://www.youtube.com/watch?v=xJ0DdVff3W8
lefty o
Re: LED shop lights
Post by lefty o » Wed Jun 06, 2018 10:55 am
i can verify for you, the ones i have in my garage and shop are not blue. just bright white.
exhaustgases
Re: LED shop lights
Post by exhaustgases » Wed Jun 06, 2018 11:34 pm
Mine too but if you watch the video's they explain how the blue is still present, similar to having an electric arc that would have a white coating over it. Amber is one color that will block it so ???? The sun is white but the intensity as well as the ultra violate that is a touch higher frequency than blue is still present.
lefty o
Re: LED shop lights
Post by lefty o » Wed Jun 06, 2018 11:49 pm
yes, there is a whole bunch of colors involved that you dont actually pick up. i was a printer for many years, my color acuity is pretty good.
user-23911
Re: LED shop lights
Post by user-23911 » Thu Jun 07, 2018 3:17 am
Some if not all high powered LEDs aren't white at all, they're 3 in 1 , as in RGB.
If you're able to break into them you can adjust the individual currents of the R,G and B to change the colour.
For example those fancy ones used for stage lighting and disco / bands. They're programmable.
For most people though, it's too much effort.
mk e
Re: LED shop lights
Post by mk e » Thu Jun 21, 2018 1:02 pm
I just put 6" recessed lights in my new shop. The ceiling is 10' and the pots are about 4' from the walls and 8' apart with 1100 lumen 13W 5k par40 bulbs.... it's like daylight in there and the shadows aren't bad with light coming from all directions. The bulbs are ge and were 3 for $18 at lowes. I'm pretty happy with the setup.
I had a bunch of 650 lumen 2700 bulbs the we use in the house kicking around I put in as I was wiring things up....that was awful.
Mark
Mechanical Engineer
