High lift doors
Heat/AC, electrical, lighting, flooring, design, construction, photos...
mk e
High lift doors
Post by mk e » Fri Sep 07, 2018 9:41 am
Not sure this is interesting to anyone other than me but I'm (slowly)building a new garage. I went with a 10' ceiling so there is no issue with the engine crane or adding a lift at some point.
That go me looking at high lift door setups to get the door up near the ceiling. I found that if I bought the doors at the door place they would install them however I wanted but the quotes were about $500/door more than the same door at homedepot....and i need 3...an my wife wants to change the 2 on the house to match what she picked for the new garage. That's a lot of money....
I found a door place online that does highlight conversion kits. They sell you brackets plus a section of track for $200 or just brackets and you cut the track off the back end of the track you have ( highlift means it doesn't need as much in back) for $125.
But then the doors we picked out (clopay) come with extension springs and highlight needs torsion....and the clopay torsion upgrade won't work either. So it needs a torsion conversion for another $200 and shipping was almost another $200. Yuck
I found a local door place that sells parts and bought the torsion stuff with highlift drums and springs and a set of winding bars for $240.
Then I just cut the back off the upper tracks and welded it to the vertical tracks for free. I bought L-brackets at lowes for $2 each to support it...so $4/door instead of $125 :)
Note the extensions need to be welded at about 6 degrees because the top roller is normally on the radius and not aligned with the other rollers.
I used the cables that came with the extension spring setup and cut to length then use a crimp on cable end...25 cents each.
It came out pretty good. I just bought parts for 1 to see how it went...even Lana said it's nice and wondered why all doors aren't done that way and that is a HUGE compliment, normally she just rolls her eyes when I show her garage/shop stuff.....the down side is she want the new house doors done the same way.
I went up 24" figuring tracks are built for 8' and I have 10. Looking at it now I probably could have gone 27" or 28".....the 10' wall sits on 3.5"-4" of block, I forgot about that.
Also note that normal openers won't work with this setup, you need a liftmaster opener that turns the torsion shaft. I'm not sure I'll ever add openers but I did put outlets in the ceiling near the shaft just in case.
Mark
Mechanical Engineer
n2xlr8n
Re: High lift doors
Post by n2xlr8n » Fri Sep 07, 2018 9:54 am
Finally!
A lifetime of study paying off. :wink:
Back to the Ferrari.
Nice job as usual, Mark.
mk e
Re: High lift doors
Post by mk e » Fri Sep 07, 2018 10:06 am
I need to get the car and equipment into the garage....so I needed a door that I could open :)
Mark
Mechanical Engineer
Leftcoaster
Re: High lift doors
Post by Leftcoaster » Thu Sep 13, 2018 1:18 am
Mark, among other talents you're "a writer born"
While your technical literacy and "can do" approach is encouraging, your acceptance of Family vicissitudes is nothing short of exemplary :wink:
mk e
Re: High lift doors
Post by mk e » Thu Sep 13, 2018 8:08 am
If only I were a speller or proofreader born.....I post some pretty egregious errors. :oops:
I started the down threat just thinking maybe I'm not the only one who never gave doors a second thought.....open/close good!. The garage on my house has an almost 11ft ceiling but the bottom of the opened door is just over 7 and Lana it always smacking the hatch into it. Working in my dad's garage as a kid I had to close the door in the hot summer to do engine work....buts it's only a couple hundred bucks to move the door up to the ceiling and be done with that nonsense.....live and learn.
Mark
Mechanical Engineer
