FrankenFerrari engine
Post photos/videos of anything* you own - Or, ask to see something.
mk e
Re: FrankenFerrari engine
Post by mk e » Fri Jan 23, 2015 8:24 am
I put some big holes in what was a perfectly good gear case cover last night. :shock:
Mark
Mechanical Engineer
mk e
Post by mk e » Sun Jan 25, 2015 11:14 am
I spent a lot of time yesterday test fitting and measuring just to be sure.....the gears seem to fit in the main housing properly so that's good.
Then I got the new bosses made and welded into the cover and did some basic cleanup to get it flat again. The bosses need to be finish machined and after pondering it a bit I decided to indicate in the bearing on the main housing, then install the cover and pop in a witness hole dead on center, then flip it over and indicate in the witness hole and I know for sure the outboard bearing in in-line with the inboard. The other option would be to pick up the bearing and pin locations and math it all into the cover but that's more chances to make mistakes and I make plenty as it is so.....easier to plug the witness holes when I'm done.
Mark
Mechanical Engineer
mk e
Post by mk e » Sun Jan 25, 2015 8:59 pm
Here it id all finished.....I hate grinding and sanding but it looks so nice once it's done.
Time to figure out what I want to do with the hydraulic throw bearing lines so I can start assembling everything.
Mark
Mechanical Engineer
Cubic_Cleveland
Post by Cubic_Cleveland » Tue Jan 27, 2015 7:32 am
Nice work Mark!
mk e
Post by mk e » Fri Jan 30, 2015 7:43 am
I was finishing up the gear hub bearing surfaces the other night and had to snap a pic.....the chips where coming off on fire. Not glowing, no the cutting oil smoking burning (I wasn't even using any) , the metal was on fire. I've never seen that before. The part came out nice though as alls well that ends well.
Just waiting on a couple small parts I need to show up then I can slap this all together.
I also got a porsche gas pedal off ebay. I'm going to try DBW on this engine thinking the 12 massive TBs are going to take some careful tuning of the pedal/TB ratio to get off idle nicely and changing values in a table is WAY easier than making new cable cams. Also the motec has nice launch control and traction control features that I'm told work better with DBW than just using the cylinder cut/timing retard mode. Anyway, when porsche first switched to DBW they dropped it into cars that were designed for cable operated throttle and had no room in the pedal box using a cable operated pedal sensor. I'm hoping I can just pop their pedal off and hook up mine and be done.....we'll see
Some time back I bough a throttle actuator on ebay from a BMW M46 which is an ITB engine with DBW so it's got a nice stand-a-lone type actualtor.
I've got to do something for brakes on this car, add a clutch master to work with the hydraulic throw-out I added to save space in the bellhousing and the the throttle so I'm thinking knock all this out next before the engine is in and it's still easy to get to everything.
Mark
Mechanical Engineer
mk e
Post by mk e » Sun Feb 01, 2015 10:01 am
The bellhousing and gear case went together kicking and screams with just about everything wanting a "tune-up" of one kind or another......but it went together.
Mark
Mechanical Engineer
mk e
Post by mk e » Sun Feb 01, 2015 9:24 pm
A little more kicking and screaming today but the engine is all buttoned up now...well except the rear cam end covers that are being made.
I think I just need to put on the starter, drop in the differ and put on the motor mount and this piece of the project is done.
I used a ferrari 360 ring gear on the flywheel I made which luck would have it happens to have the same gear teeth chevy uses so I got a gear reduction starter for a chevy and put a new nose on it to get it in the space I had. Hopefully it spins the engine ok because while the teeth are chevy there are only 106 of them (IIRC) and there is a lot of friction going on in this engine. so many things to worry about........
Mark
Mechanical Engineer
BCjohnny
Post by BCjohnny » Mon Feb 02, 2015 6:08 pm
mk e wrote:.....it happens to have the same gear teeth chevy uses.....
For future reference it's 12/14 DP, 20deg pressure angle. Very common amongst OEs. Go looser rather than tighter on the mesh, within spec.
"If an honest man is wrong, after demonstrating that he is wrong, he either stops being wrong or he stops being honest." Anon
les327
Post by les327 » Tue Feb 03, 2015 3:19 pm
WOW
miniv8
Post by miniv8 » Wed Feb 04, 2015 5:33 pm
This build is awesome.
mk e
Post by mk e » Wed Feb 04, 2015 7:41 pm
Thanks!
The diff went in yesterday.....I think it's ready to drop in the car and start fitting all the other stuff. I know I should be planning to fire this on the dyno but I really want to see the car rolling sooner rather than later so the dyno will probably need to wait until fall unless something goes wrong and I need to pull the engine sooner.
Mark
Mechanical Engineer
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Fri Feb 06, 2015 4:52 pm
NEVER, EVER, LET A GEARHEAD WITH TIME TO SPEND NEXT TO A BRIDGEPORT AND A MIG WELDER.NEVER.
:D :D :D just kidding, you did an awesome re-engineering job, I bet you will grin ear to ear when this beast fire up!
Keep us updated.
'71 Z28
Pump gas N/A SBC 427
3308 lbs-29x10.5 Hoosiers
https://www.facebook.com/hotcampinas/vi ... nref=story
mk e
Post by mk e » Wed Feb 11, 2015 12:00 pm
BrazilianZ28Camaro wrote:NEVER, EVER, LET A GEARHEAD WITH TIME TO SPEND NEXT TO A BRIDGEPORT AND A MIG WELDER.NEVER.
Keep us updated.
LOL
I just put highlights here, if you want to follow the day to day battle I post that on my own site:
http://gemellocattivo.com/forum/viewtopic.php?f=2&t=8
Mark
Mechanical Engineer
mk e
Post by mk e » Wed Feb 11, 2015 12:07 pm
Speaking of highlights, I dropped the engine in the car last weekend....and there was AT LEAST 1/4" to spare....after I stripped off what I could and got it twisted just right :)
The way things worked out the flywheel is sitting right over the frame rail and if I shake the engine on it's motors I head what I think is the flywheel cover banging....I need to shim the mount up 1/8"..or maybe 1/4".
Mark
Mechanical Engineer
Kenova
Post by Kenova » Wed Feb 11, 2015 12:14 pm
I can't wait to see and hear this thing driven in anger. :twisted:
How long have you been working on it?
Ken
Over the hill but still learning!
Retaining it is the hard part.
