SBC Connecting Rod Length
GotSomeRust
Post by GotSomeRust »
I was told that I should use a 6 inches connecting rod in my Chevy 350 instead of the stock length of 5.7 inches. What are the advantages/disadvantages of using a 6 inch? Thanks in advance for the info...
83 Cutlass
stealth
Post by stealth »
Oh No.... :shock:
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
The piston is very much lighter in weight-about 100 grams
JOE SHERM AN RACING
GotSomeRust
bigjoe1 wrote:The piston is very much lighter in weight-about 100 grams
JOE SHERM AN RACING
Huh?
83 Cutlass
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
What I am saying is that the rod length is very UNIMPORTANT- but the piston for the 6 inch rod will be much lighter---GET IT ????
JOE SHERMAN RACING
Post by 1989TransAm »
Right. Usally the longer the rod the lighter the piston and the rotating assembly.
BGriff
Post by BGriff »
Longer rod, longer dwell at TDC, better for high RPM HP.
Short rod, better for low end torque, more side loading at piston skirt.
Too many hobbies
GotSomeRust
bigjoe1 wrote:What I am saying is that the rod length is very UNIMPORTANT- but the piston for the 6 inch rod will be much lighter---GET IT ????
JOE SHERMAN RACING
Yes, thank you.
83 Cutlass
k-star
rods
Post by k-star »
BGriff wrote:Longer rod, longer dwell at TDC, better for high RPM HP.
Can you share some of your testing data to prove this??
Like how much tq increase did you see in A-B-A testing with the shorter rod??
Please list all the info of each combo and the actual TQ increase numbers.
Keith
“If I hit you with this you’re going to be numb, that’s why they call them numb-chucks “Si Robertson
CNC BLOCKS
Post by CNC BLOCKS »
We see a big differance on the 2 bararrel circle track engines going from a 5.7 to 6.250 rods and from what I have seen they male peak power about the same RPM but the 6.250 rod will carry alot longer then the short rod engines.
The cam will be different for a longer rod engines as well.
Website is up and running
Machine shop tour
Monthly Specials
3V Performance
Post by 3V Performance »
CNC BLOCKS wrote:We see a big differance on the 2 bararrel circle track engines going from a 5.7 to 6.250 rods and from what I have seen they male peak power about the same RPM but the 6.250 rod will carry alot longer then the short rod engines.
Seen the same here..
3V Performance
" ENGINES WITH AN ATTITUDE "
980-222-7230
k-star
rods
Post by k-star »
Carl or 3V, can you give some actual numbers??? When you say carry it longer I assume you mean the peak HP father up the RPM range. How much farther???
Is this something that is only found with the 2bbl engines???
Keith
GotSomeRust
Sorry to be dumb, but (referring to CNC Blocks post) what needs to be different about the cam when using 6 inch connecting rods? That doesn't make sense to my little brain... Thanks
83 Cutlass
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
What I have seen with the longer rod is that the engine does not nose over as bad above the HP peak-- say the peak is at 7000, with a longer rod , it can carry the better power way uo to 8000. On the other hand, with a shorter rod, even when the peak is at 7000, by 8000, the power will drop off 30 to 40 HP-- The differance might be 25 more HP with the loger rod at 8000
JOE SHERMAN RACING
williamsmotowerx
Post by williamsmotowerx »
Friction kind of "squares" with RPM. Exactly what BigJoe said... doesn't nose over as hard.
I'd guess a faster ramp rate cam for longer rod, plus a tighter LCA
