There is no magic figure for toe in. It is determined by many things, basically you actually want the tyres to run parallel, (not toed in or out), when the vehicle is in its most used/average speed range and running in a straight line.
This is worked out/affected by things like, castor angle= ammount of pressure on tyres trying to give toe in or out,
bush material= the softer the bush material or the more bushes in the set up the more toe in you need to combat frictional force which wants to create toe out,
tyre width=rolling friction which depending on rim offset and suspension design can increse dynamic toe in or out.
The same car with the same suspension will require a different toe setting if you change, rim offset, or, tyre compound/type, or, bush type-rubber/urethane/solid, or, almost any other thing.
on the track you will want a different toe setting for a track with lots of corners and minimal or sloe straights as compared to a fast track with long higher speed straights and lighter corners.
For some drag apps with a basic front end that runs solid bushings, 0 camber and a some castor for stability and thin tyres you may need very minimal toe in.
On some AWD/FWD apps you may actually need some toe out to allow for the driving force thru the front wheels being able to pull some toe in, this depends on the suspension goemetry of course.
bump-steer ?
Return to “Chassis / Suspension / Body”
Jump to
- Speed-Talk
- ↳ Announcements
- ↳ In Memory of Don Terrill
- Technical
- ↳ Engine Tech
- ↳ Advanced Engine Tech
- ↳ Vintage/Classic/Historical Engine Tech
- ↳ Chassis / Suspension / Body
- ↳ Electric & Hybrid Vehicle ** NEW **
- ↳ Shop & Garage Tech
- ↳ General Tech
- HotPass Members & Guests
- ↳ Subscribe to HotPass
- ↳ Speed-Talk Vendor Marketplace
- ↳ 3V Performance Engine & Valve train Development
- ↳ Auto Gear Equipment
- ↳ CCA Racing Products
- ↳ Competition Fuel Systems
- ↳ Heads 1st
- ↳ Jones Cam Designs
- ↳ Koehler Injection
- ↳ Lightning Racing Carbs
- ↳ MaxRaceSoftware
- ↳ PBM-Erson
- ↳ Schmidt Motor Works
- ↳ Speier Racing Heads
- ↳ Stan Weiss' Software
- ↳ TFX Engine Technology Inc.
- ↳ Speed-Talk interviews
- ↳ David Vizard forum
- ↳ HotPass Advanced Tech forums
- ↳ Valve Train
- ↳ EFI
- ↳ Supercharging
- ↳ Chassis setup
- ↳ Transmission & Gearing
- General Category
- ↳ Industry / Business
- ↳ Show & Tell
- ↳ Forum Help / Questions / Tips
- Classifieds
- ↳ Race Cars & Parts - For Sale or Wanted
- ↳ Shop Equipment - For Sale or Wanted
- ↳ Other - For Sale or Wanted
- Offtopic forums
- ↳ Offtopic Forum
