whats the difference between 1.5 and 1.6 ratio rockers ??
junior a
Post by junior a »
i hand order new ones to fit my 155 springs,my old ones was 145 springs
rmcomprandy
Post by rmcomprandy »
A tenth of a ratio.
The 1.5 and 1.6 is the multiplication factor which that rocker arm has between the lifter rise and lifting the valve.
BrazilianZ28Camaro
Post by BrazilianZ28Camaro »
You can expect about 14 hp more with 1.6 Roller rockers in a average 350...
Just be careful with coil bind and piston to valve clearance.
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
That 14 HP is about the BIGGEST increase I have ever seen. If you put themon both sides, it will usually cut that down to about 7 or 8 HP, not 14
JOE SHERMAN RACING
Troy Patterson
Post by Troy Patterson »
bigjoe1 wrote:That 14 HP is about the BIGGEST increase I have ever seen. If you put themon both sides, it will usually cut that down to about 7 or 8 HP, not 14
JOE SHERMAN RACING
So, just put them on one head for best power? :lol:
BrazilianZ28Camaro
Some sources claim 16 hp from factory stamped rockers to 1.6 RR on undercammed underheaded mild 350 engines...
But I think is a bit high too :roll:
On a well developed cam/head/exaust engine increased lift and valve acceleration from bigger ratio rocker can offset any possible gain, mainly on exaust due to increased valvetrain instability and too much overlap area to the engine.
Just my $.02
NEW BEST ET
jeff swisher
Post by jeff swisher »
so many times i have witnessed a swap from stock rockers to 1.6 rollers and nothing changed except the thickness of your wallet
but street cars with cams in the 218-240 range at .050
you might see it at the track like 1 or 2 tenths but i have never felt it in my buttometer
never did just the 1.6 on the intake side though
