nitrous on alky?
nitrous on alky?
thoughts? anyone done it a lot here? 15.7:1 compression SBC, alky motor, thinking about hitting it with some nitrous and c16 with a separate fuel system. any thoughts?
- Dave Koehler
Re: nitrous on alky?
Looks nice, but i have two holley 650 dp carbs on a holly prodominator tunnel ram.. any suggestions? I have a plate kit for a dual carb setup and have been thinkin about starting on a small tune up and going from there.. any expeirience with jetting on c16 over alky? Thanks again!!
- Dave Koehler
I think what Dave is saying is he has a lot of time, experimentation, and the info is not for public consumption but clients only. I'm sure he uses a form of the old 297 patent as it is the best there is. Knowing the % is the real secret. Getting it there is easy. I'd work with him if you are serious about the direction you are talking about. Good luck,
Joe
Joe
well, being as i am serious about it, and haved succesfully tuned many nitrous cars on pump 93 as well as ethanol, and c16, Ill just give it a go on my own.. Im sure Dave has TONS more expierience than I in this department, but if no one wants to offer any advice Ill teach myself on my own as I have on everything else.. Its just a toy car anyways..
Make sure your alcohol is as free of moisture as possible, the hardest thing about alky and nitrous is getting/keeping the alcohol atomized or you'll have dangerous lean spots and backfires. If you're strictly going to run plates I'd work on making a custom 3 bar discharge with the center one using standard V dual outlet for the nitrous, then two single outlet bars for the fuel, that way you can get 90 degree of nitrous atomizing the fuel.
-Carl
-Carl
