....or keep re-electing progressive socialistsAMorrison wrote:You could always marry my ex wife.
How to create a parasitic drain?
Re: How to create a parasitic drain?
"do it right or do it right away"
http://www.motionmachineinc.com/
https://www.youtube.com/watch?v=ZgIZbveknDs
Here's one for you. A bit off-topic but still a good one. Had a customer years ago that had a tow truck business. He had 2-way radios in the truck (big 100 watt GE). He came in one day and said that for some reason every time he took his big diesel wrecker up on the freeway, the 2-way radio would stop working. Yet, whenever he would arrive at my shop the radio worked fine. Yes, I went with him and sure enough as soon as he got up on the freeway and up to speed, no more 2-way radio. Anyone want to guess what caused this?
pheyden wrote:Here's one for you. A bit off-topic but still a good one. Had a customer years ago that had a tow truck business. He had 2-way radios in the truck (big 100 watt GE). He came in one day and said that for some reason every time he took his big diesel wrecker up on the freeway, the 2-way radio would stop working. Yet, whenever he would arrive at my shop the radio worked fine. Yes, I went with him and sure enough as soon as he got up on the freeway and up to speed, no more 2-way radio. Anyone want to guess what caused this?
Wild guess. The force of the air caused his whip antenna to go horizontal and changed it from omnidirectional to more of a directional -- if it was mounted on the back of the cab that surface might have acted as a vertical ground plane.
Actually, some bright installer, when looking for a good 12V power source (remember a 100 watt transmitter will draw many amps) found a huge power wire on the back wall of the cab. It turned out that it was part of a switching circuit for the 2 speed rear end. Ergo - When he was up on the freeway at cruising speeds, he was in high range, thus no radio. Took a bit to find that one.
Paul
Paul
pheyden wrote:Actually, some bright installer, when looking for a good 12V power source (remember a 100 watt transmitter will draw many amps) found a huge power wire on the back wall of the cab. It turned out that it was part of a switching circuit for the 2 speed rear end. Ergo - When he was up on the freeway at cruising speeds, he was in high range, thus no radio. Took a bit to find that one.
Paul
Interesting -- it would have cut off his radio like a switch then. I took it that the radio was still on but would not "work" as in receiving signals.
I had this one for real on my '70 Z-28. After I re-arched the rear springs the battery started going flat. The added rear height was just enough to tilt the mercury switch..Hairyscreech wrote:If its a saloon with a trunk light then rigging the micro switch that lights the light is a good one, it will keep the light on even when the boot is shut, thus it takes a while to find as you only spot it being on all the time if you can see into the trunk when its shut.
Same deal with a glove box light, its supposed to be on when the glove box is open so no one will suspect a fault unless they can see its still on when the glove box is shut.
Both of these are pretty common faults in the real world.
Rig the fuel pump relay to run the fuel pump all the time? However i guess that will only work if the pump is really quiet or where they are doing it is noisy.
