Bearing nomenclature
- BrazilianZ28Camaro
I'm just curious, why .001" bearings are called "undersize"?
I understand they increase the running clearance by .001 having the I.D bigger in relation to a STD bearing, so, shouldn't they be called oversized?
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
NEW BEST ET
Re: Bearing nomenclature
CB663H1 is an undersize bearing. It doesn't add .001" it takes away .001". CB663HX adds clearance.
LIke robert1 posted, 1 bearings tighten the clearance .001BrazilianZ28Camaro wrote:I'm just curious, why .001" bearings are called "undersize"?
X bearings add .001
Ok, thanks but lets say If you have a set of .020" rod bearings and need .001" more clearance you should get .021" rod bearings called undersize?
NEW BEST ET
NEW BEST ET
lorax wrote:LIke robert1 posted, 1 bearings tighten the clearance .001BrazilianZ28Camaro wrote:I'm just curious, why .001" bearings are called "undersize"?
X bearings add .001
I do believe these are from Clevite PNs?
Do you know how King bearings define their PN code in relation to size?
Say you have the #CR 807SI 020 and need .001 more clearance, do you get the CR 807HPN 021 or ??
I looked at the King web site but it was no help.
NEW BEST ET
NEW BEST ET
No, you would get .019 if you use a Clevite. If you use a King, then you get 20XBrazilianZ28Camaro wrote:Ok, thanks but lets say If you have a set of .020" rod bearings and need .001" more clearance you should get .021" rod bearings called undersize?
lorax wrote:No, you would get .019 if you use a Clevite. If you use a King, then you get 20XBrazilianZ28Camaro wrote:Ok, thanks but lets say If you have a set of .020" rod bearings and need .001" more clearance you should get .021" rod bearings called undersize?
thanks Lorax
That's what I thought=.019" undersized in relation to a STD bearing.
NEW BEST ET
NEW BEST ET
Got it...
and the Sealed power PN for that size is the Z87100CH19...
NEW BEST ET
NEW BEST ET
You are more likely to find the +/- .001 bearings in Clevite or ACL. FM seems to be hard to get these days and always seem to be back ordered.
The others seem to have good stock when needed.
You can get a 009 .010 .011-.019 .020 .021 for under sized journals and a 1X for less clearance and a -.001 .002 in the HP series of bearings.
One thing to note...first I know your overseas so it it tough anyway.
Bearing QC is not very good and you can end up with a set of std and a set of .001
that only change the clearance from .0003 to .0012
so if you can check the clearance with what you have ..ball mic the bearing and
then who ever you order your bearing from see if they can ball mic the thickness
and do the math to make sure you get what you need.
OK
Thanks for the tips fellas.
NEW BEST ET
NEW BEST ET
Brian B wrote:One thing to note...first I know your overseas so it it tough anyway.
The problem with checking the bearing shell thickness is that this will not necessarily tell you what the verticle oil clearance will be when the bearing is installed. There may be variations in housing bore diameters and the various bearing manufacturers do have differing spec's for bearing crush. The only way to verify verticle oil clearance is to torque the bearings in place and measure with a good quality dial bore gauge.
Bill
SAE Member (30 years)
