Hooters cup into road race car
Figured I'd post here, haven't really found a forum yet that this fits into
It basically starts with this, found it locally for $1380 after taxes and dealer fee
k1ob.com
Re: Hooters cup into road race car
I can only work on it when I have a break from school so its been sporatic, this is probably a few months after I got it, wasn't sure if I could do it or not initially
This part sucked, did in the corner of a garage in the middle of summer, hot and sanding dust everywhere
Got the calipers for $120
k1ob.com
Put some old nascar tires on it
Figuring out motor mounts, which may be getting cut off, depending on which motor I get
Start of radiator and oil cooler, bought on ebay for $275 shipped
Had to make the lower bumper support, and made the grill bolt in not rivet
oswin/6fcb61ac-b434-4175-a2e1-1bfb10f85c29_zps518dda20.jpg[/img]
Before welding
Made the frame from 1/2" square tubing
Tow hook out of 1/4"
Before welding
k1ob.com
Duct further along
Also scored a bunch of parts for $300 bucks, someone getting rid of all their old racing junk, also picked up a bunch of springs, pretty much all mismatched though
k1ob.com
Took apart the quick change and pressed out the tube and flipped it 180*, it was positive 1.8* before and now its 1.8* negative along with the other side. Unfortunately the ring and pinion is shot. The rear end is a locker though which is nice. Need to find a cover with the gear lube pump.
brake ducts mounted
1 11/16 from sway bar, need to do the mounts on the lower arms still. Also need to do shock mounts
brake ducts mounted
k1ob.com
Lower control arms all squared up to the best of my knowledge, and the frame mounts on the upper are squared up, just need to get the correct length a-arm which I believe is 8.25". Waiting on a .5" longer ball joint to confirm though, that length should allow me to get the right camber only using a little shim on one side of the car and none on the other
I also have been polishing everything that is aluminum before installing, the steering column and rear fender tubs look a lot better now, not mirror polish but just enough
k1ob.com
Very nice work and you'll get there. Building it yourself, you'll know the car inside and out. BTDT
Along the way, I learned "There's nothing so expensive as a cheap old roller race car."
Man, that must be a blast to drive.
Several examples of exactly this in TX at Motorsports Ranch and Eagle, its actually pretty economical in the long run.
ctk30 wrote:Duct further along
You done good with this,,I'm constantly finding "lot" sales like this all the time where I live,,up here in north Ga,,basically because there are a lot of racing teams,,selling out,,they just can't afford it any longer,,,also ebay has tons of stuff being sold out.You really have a great place to work on your car,,as well,,the lift has to be a giant asset,,I remember helping guys that had NO lift,,,everything was done on the ground,,,which wasn't all that bad,,,,just real time consuming.
Thanks, the lift is my uncles, but he lets me use it from time to time, he is going to take a body off a car though for a frame off soon I think thought so I'll have to find something else
I did some sheetmetal work in the back, the fuel cell area is all sealed in now. I got a bead roller for christmas so I bead rolled everything, it looks nice
I was in a rush to get back to school that day so I didn't get any pictures, going back in a few weeks hopefully and will be able to get some work done
I did roll it out and take some pictures earlier in the day though
k1ob.com
