-A friend has acquired several large pieces of tubing that are filled with liquid mercury and have been used for racecar ballast.
-We know that it is hazardous material and probably controlled by the EPA, but is there someplace this could be sold?
-I looked up the cost of liquid mercury and it's something like $3400 a gallon.
what would you do with 300# of liquid mercury
Mercury
According to my Chemical Dictionary a large portion of used mercury is reclaimed by re-distillation. Its uses include amalgams, as a catalyst, electrical components, explosive compounds, cathodes for production of Chlorine, and caustic soda, scientific instruments, Mercury vapor lamps, extractive metallurgy, mirror coatings, arc lamps etc.
I'd probabably start by calling around to scrap metal brokers that deal with exotic metals, or contacting major companies that use the stuff to find out who re-claims used mercury.
The other possibility would be to touch base with a major engineering college with a metallurgy department, to see if they know any contacts that would help. It used to be used in gold extraction, and dental amalgams so there may still be some companies serving those industries too.
A look at Thomas Register for mercury manufactures/refiners might find you a contact as well.
Best I can think of at the moment.
I can't believe someone used a liquid metal for a race car ballast, but if you can find the right outlet I would guess you cold get some money for it.
Larry
Larry
mercury recovery
Found this fact sheet, looks like mercury recycling has pretty well glutted the market so companies that recycle it will take it off your hands and may even charge to do so --- does not look good !
www.epa.gov/region6/6pd/pd-u-sw/mercury.htm
http://www.metalworld.com/a/0165.html
http://www.bethlehemapparatus.com/page01.htm
http://www.dep.state.pa.us/dep/deputate ... lities.htm
Simple google search on +mercury +recovery
Larry
Larry
