Horsepower/Torque required to drive 9 inch diff
Transmission to Rear-end
RT Machine
Post by RT Machine » Tue May 02, 2017 7:24 am
How much horsepower/ Torque is used to drive the average 9 inch Ford rear axle as compared to a Salisbury type axle, say GM 12bolt / Dana 60 etc I have been told it is around 50 HP loss in the driveline, because of the pinion position as compared to other axle designs, also with a 600hp engine with 4 speed manual and 3.5 :1 9 inch rear, what loss of HP would one expect to measure at the wheels on typical chassis dyno ?
Re: Horsepower/Torque required to drive 9 inch diff
Post by pdq67 » Tue May 02, 2017 12:05 pm
I doubt if it is 50hp??
This info is out there but probably will be hard to find!
But I will say that a 9" is one tough rear end like the Dana 60 is so maybe hp vs overall strength might be worth the less eff. gear train...
And I have a stock 3.31, 12-bolt posi- under my '67 Camaro car!
Speedbump
Post by Speedbump » Tue May 02, 2017 1:34 pm
There was a good thread about this very thing in the not too distant past. IIRC, someone respectable in racing, maybe Joe Sherman, said cars he had done the change to 9" lost a tenth or so with no other changes. A search should find the thread.
Speedbump
"If it was easy, everybody would do it."
Post by pdq67 » Tue May 02, 2017 2:59 pm
Big Joe 1 will know!
turbo2256b
Post by turbo2256b » Tue May 02, 2017 4:11 pm
mOST OF THE POWER LOSS IS IN THE PINION CARRIER GO WITH WHAT THEY call a NASCAR pinion carrier issue gone.
1972ho
Post by 1972ho » Tue May 02, 2017 5:32 pm
The ford 9 inch also has 4 ring gear tooth engaged into the pinion vice only 1 to 2 for other types.Also anybody ever ran there backlash at .015 I've heard more is faster.
1972ho
Post by 1972ho » Tue May 02, 2017 5:50 pm
http://www.truehi9.com/gears2.html Check this article out on the different rears.
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 » Tue May 02, 2017 8:15 pm
I will step in here and re affirm that again--- I have seen it happen about three or four times-- Going from a Chevy 10 bolt or 12 bolt to a ford slows the car down EVERY TIME
JOE SHERMAN RACING
user-23911
Post by user-23911 » Wed May 03, 2017 2:11 am
You forgot to mention how fast you want it to spin.
At a snails pace it takes just over zero torque and HP to drive, the faster you want to go, the more it takes.
It's proportional to road speed.
If it's not built right, like the gears not meshing correctly, it'll take more power to drive, noisy, it'll get hotter and spit out the oil AND , worst case, spit out the seals too.
RT Machine
Post by RT Machine » Wed May 03, 2017 5:03 am
Thanks for the info, cheers
Post by MadBill » Mon May 08, 2017 8:38 pm
bigjoe1 wrote:I will step in here and re affirm that again--- I have seen it happen about three or four times-- Going from a Chevy 10 bolt or 12 bolt to a ford slows the car down EVERY TIME
JOE SHERMAN RACING
I posted this a while back; here's the proof of Joe's words.
larry woodfin
Post by larry woodfin » Wed May 10, 2017 9:47 pm
In my opinion, a specification is missing from the test comparison. In my experience, many drag race gear sets are built/assembled with way too much bearing preload.
With any type or manufacturers rear axle assembly it should be VERY easy to turn by hand. The preload for both pinion bearings and side bearings should be just barely, almost no preload, just take the slack out.
The first thing you will notice, the car will be VERY easy to push. With the car on jack stands the rear wheels should turn easily, just a light touch should easily turn the wheels.
I would like to see the data with a 9" rear adjusted as I described.
user-23911
Post by user-23911 » Thu May 11, 2017 1:34 am
To add to the above, the way to measure it is with an inertia dyno.
Do a run down test.
That's getting the flywheel to full speed, drop it into neutral, measure the run down deceleration.
Tyre pressures are a big variable too.
The Badger
Post by The Badger » Fri Mar 16, 2018 3:44 pm
Figured I'd dig this post up rather than start a new one, anyone have any testing to compare the ford 8.8 for power to turn? I was under the understanding since its like the 12 or 10 bolt it would be similar.
peejay
Post by peejay » Sat Mar 17, 2018 7:31 pm
I'm not so certain about the bearing preload having an effect, WHEN UNDER MAX POWER, because the bearing loads and case distortion will have a much greater effect on bearing load than the preload.
Now, as far as cruise drag is concerned, yes, then bearing preload makes a huge difference... GM went with an iron differential case on some of their newer cars because they could run less bearing preload than with an aluminum case, so the reduced drag was more beneficial for fuel economy than the lighter weight.
The 9" having a super low pinion height is why it is so strong and also so lossy, it's closer to a worm gear than a bevel gear.
