WTB Y Block Ford Parts
liqu
Post by liqu »
Ported heads for a Y Block Ford, steel cranks, or any other modern (if possible) speed equipment (no 3x2 manifolds) good or bad.
BirdMan
Re: WTB Y Block Ford Parts
Post by BirdMan »
I believe I have a stock 292 crank if you are int.
Dale C.
liqu
Post by liqu »
Hi, I am looking for steel cranks, steel cranks have no center counter weight, and the flywheel flange is round (no 1/2 moon cut out)
Post by pdq67 »
liqu wrote:Hi, I am looking for steel cranks, steel cranks have no center counter weight, and the flywheel flange is round (no 1/2 moon cut out)
Didn't the old 292" truck engines have SOME forged cranks in them?
liqu
Post by liqu »
Yes, most 3/4 ton and up, 1961 and newer trucks have a steel crank, however most will need a snout repair (loose damper)
