AMC 327 - 443 CID Rambler V8
- amcenthusiast
Re: AMC 327 - 443 CID Rambler V8
Showing ported '64 AM RV8 siamesed center port, from outlet side, currently in use on this 443 engine:
[img] [/img]
[img] [/img]
XRV8 Race Parts website: http://amcramblermarlin.1colony.com/
YouTube video of 443 XRV8 Gremlin: https://www.youtube.com/watch?v=2DmFOKRuzUc
- amcenthusiast
Showing other end port, ported, '64 Rambler V8 head, currently in use on 443 stroker block:
[img] [/img]
[img] [/img]
- amcenthusiast
Shop drawing with some illustration for explanation:
-since hot air flows faster than cold, the exposed roof in section 3, having water jacket underneath, is designed to increase scavenging. (red line/no water jacket, blue line/water cooled exhaust vapor)
The 'loudspeaker shape' of the port's midsection gives these engines their distinctive signature sound. (section 2)
[img] [/img]
[img] [/img]
- amcenthusiast
Same ports, in sequence, confessing much work done to enlarge the valve pocket outlet area:
[img] [/img]
[img] [/img]
- amcenthusiast
2nd head, in sequence, confessing much work done to enlarge valve pocket outlet area:
[img] [/img]
[img] [/img]
- amcenthusiast
Ported '64 heads for 443 CID Rambler V8, showing unfinished exhaust port outlets having gouges from 'leaning on it', caused by rubbing shaft of porting tool, in order to spend time 'going around the corner' to enlarge the valve pocket outlet area deep inside the 'long and curvy' port:
[img] [/img]
[img] [/img]
- amcenthusiast
Ported '64 Rambler V8 heads for 443 CID Rambler V8, 2nd head, unfinished outlets showing gouges caused by rubbing the shaft of the porting tool in order to 'go around the corner', to enlarge the valve pocket outlet area:
[img] [/img]
[img] [/img]
- amcenthusiast
Exhaust port outlets gouged by porting effort, caused by rubbing long shaft 'to go around the corner' (shown by shop drawing):
Showing DIY brazing pit used to repair exhaust port outlet shape, also to fill void in center port roof after removing 'top bolt hump':
[img] [/img]
[img] [/img]
- amcenthusiast
'64 Rambler V8 heads for 443 stroker, fully ported exhaust ports, gouged outlet repair; post brazing, pre-finishing:
[img] [/img]
[img] [/img]
- amcenthusiast
'64 AMC 327 heads reworked for 443 stroker application; showing post-brazing, center port top bolt hump elimination plug void filled and ground smooth:
[img] [/img]
[img] [/img]
- amcenthusiast
AMC 327, '64 head, exhaust port rework for 443 stroker application; brazed outlet repairs getting ground flush:
[img] [/img]
Second head:
[img] [/img]
[img] [/img]
Second head:
[img] [/img]
- amcenthusiast
AMC 327 XRV8 Race Parts, exhaust ports reworked for 443 stroker, finished:
[img] [/img]
Second head:
[img] [/img]
[img] [/img]
Second head:
[img] [/img]
- amcenthusiast
Next, showing pics of intake ports...
- amcenthusiast
'64 AM RV8 intake ports; stock vs ported for 443 stroker:
[img] [/img]
[img] [/img]
- amcenthusiast
'64 American Motors Rambler V8 heads; unfinished reworked combustion chambers for 443 stroker application:
[img] [/img]
[img] [/img]
