AMXstocker1 wrote:According to quarter pro, the higher rpm engine would be a little quicker i increased shift point and converter stall and launch rpm all by the same 900 to try to duplicate the power curve that the car would see going down the track, and move gear ratio so finish line rpm was just over peak on both. i'm curious as to why its quicker you would think with everything spinning faster it would see more friction loss but i could be wrong or have the way that works backwards.
Im not familiear with the program BUT, it should be showing that you are reaching a higher MPH earlier on the track when adjusted for the higher rom engine, there is your faster car right ther, average mph across the track is higher, quicket et.
There is more than just friction here with the higher rpm. The way the convertor works, the way the lower rear gear works and the way the engine recovers on shift are all factors that allow slightly faster acelleration up to peak mph.
