Mix sbc main bearing question
I'm replacing all the bearings and bought a full set already and something just occurred to me. I've had a set of sbc main bearings(same brand/size/part number) that the rear was used so just the 4 narrow upper n lowers. Now I'm no bearing expert but could I use just uppers so I'd have a full groove? Next question, how much narrower are the HP style bearings? This is not a fresh high dollar engine just a worn sbc, so I don't plan on getting a ton of miles out of it and if I can ghetto narrow bearing by having a full groove. I'd never buy two sets to do it on purpose but if I got em already and one set is incomplete anyway. Also installing a 10% more volume pump I have.
- BigBlockMopar
- Momentary Specialist
Re: Mix sbc main bearing question
I've used another set of bearings before to make a fully grooved set of them in a build.
This was on a bigblock Mopar but as long as the bearings spec out right against eachother.
First off if the Crank is fully crossdrilled you do not need fully grooved main bearings and you would just be wasting some oil pressure and volume on them not to mention likely making oil windage control harder!
Same can be said about fully grooved main bearings no matter the crank oiling strategy!
Crank is not cross drill, engine has tray and custom baffling.
Reduction in friction just like narrow bearings
is there less friction with a grooved bearing Vs a narrower bearing if they both have the same surface area/squareinx". 2 different then a single on the only bearing half that really has any load.
It doesn't really work like that, and the loss of oil control will negate any frictional gains if there were any.
Grooved tyres are more able to cut through a film of water and contact the road surface below. A smooth tyre is much more able to have a wedge of water separate it from the road. I can imagine grooved lower main bearing halves are much the same situation as a grooved tyre as regards the ability to cut through a film of liquid so that the two surfaces come in contact.
All you are doing is sending oil to the rods all the time. Why do that if you don't need to?
My thought was to be close to the same, not less than narrow.allencr267 wrote: ↑Mon Oct 02, 2017 3:22 pm is there less friction with a grooved bearing Vs a narrower bearing if they both have the same surface area/squareinx". 2 different then a single on the only bearing half that really has any load.
As a few have pointed out the oiling could negate the friction reduction, depending on scraper maybe or vac pump.
Compromise for everyone's sake just get these Federal Mogul bearings they are 3/4 grooved.....
Link: http://www.jegs.com/i/Sealed-Power/844/ ... 4294829509
Disclaimer....I'm a reformed "Mopar Dude" trying to rev a 340 Duster to higher than 7200RPM levels with a stock oiling system that can give you....Chevreligion.....when your buddies 69 Z/28 regularly SCREEMS to 7500RPMs with no ill effects.....Mopar Dudes LOVE fully grooved main bearings.....Chevy guys know the lower groove greatly reduces the load carrying capacity of the oil wedge between the crank journal and the bearing.....Former Mopar Dudes realize they wasted years of their lives and many dollars trying to make an A motor perform like a Small Block Chevy....given the lousy oil galley routing of the Mopar motor....that was the true cause of all the lost rod bearings....AND even FULLY GROOVY main bearings aren't going to cure crappy engineering
Fully grooved main bearings provide no benefit over 180 degree grooved upper shells. As has been pointed out in previous posts, the groove in the lower shell disrupts the formation of oil wedge between the shell and crank journal. This will result in the bearing shell coming into direct contact with the crank journal and this is not a good thing, as the bearings will get wiped out.
In my opinion 3/4 groove main bearings do not result in any performance benefits either. The 180 degree grooved upper shell delivers oil into the eccentric area of the upper and lower shells, whereupon the oil forms a wedge as the crankshaft rotates.
Bill
SAE Member (30 years)
So narrow bearings are the devil too
