Header primary pipe sequence into collector for 4/7 swap
maxracesoftware
Re: Header primary pipe sequence into collector for 4/7 swap
Post by maxracesoftware »
redliner wrote: Wed Oct 04, 2017 10:18 am Hey guys I am getting ready to build a new set of headers. I have a sbc with a 4/7 swap in the firing order and I would like to place the primary tubes in the collector in the order which helps evacuate the cylinders the most effectively. Am I over thinking this or..... I have the pipemax program which has told me the diameter and length needed but I wondered about placing them in the collector in a certain order... These fenderwell headers for my 42 Stude coupe will be 2 " for about 10 " then 2- 1/8" for about 20" finishing with a 16" 3- 5/8" collector.
I was shocked to find out that the 900+ hp ProStock truck 358 was running a primary of 1.625,
I don't know what the step lengths were but It was smaller then I would have ever guessed.
the main reason why your calculated Header Specs are larger than a ProStock Truck 358
is your Compression Ratio is only 11.5:1 -vs- a ProStock Truck 358 's 15:1 + Compression Ratio + the VE% is way less than a ProStock Truck 358
this will cause your EGT's to be higher , making a larger diameter tube necessary .
i ran a 3-Step 1.875,2.000,2.125 3.500 Collector on my 355cid with 13.7:1 CR
so a 2-Step 2.000,2.125 3.500 Collector is very reasonable
i've run that much Header on many 377cid to 434cid with great Dragstrip and Dyno results .
Also you made a mistake on number of Intake and Exhaust Valves per Cylinder
your Inputs should have a value = 1 per Cylinder , but you entered 2 Intakes and 2 Exhaust Valves per Cylinder
MaxRace Software
mk e
Post by mk e »
In-Tech wrote: Thu Oct 05, 2017 11:36 am No need for a tool(I've not seen that one you speak of on my windows machines). Shift/Print Screen(look at your top keys to find it), open up paint(in all windows programs under accessories), Ctrl V will paste it, save as .jpg to desktop for ease of finding it. Post here :)
The program call "snipping tool" does all those sets automatically for you. It started at win 7 I think, just click the windows icon in the bottom left and type snip, it should pop right up....its really handy.
Mark
Mechanical Engineer
GARY C
Post by GARY C »
The PS truck comment was from me, I knew compression played a part but didn't realize it was that much thanks for the clarification.
maxracesoftware
here's a 414cid engine similar to yours
but it has 13.5:1 CR so it will like a smaller tube Header than if it were 11.5:1 CR
notice its making 700 HP as early as 6500-6600 RPM with the larger tube Header + higher Peak TQ
i wish at that time i would have had another pair of even larger Headers to test
Link
http://www.maxracesoftwares.com/forum/v ... ?f=5&t=252
MaxRace Software
maxracesoftware
here's a 420cid with Pump Gas and 11:1 CR
that likes a large Header
Headers 2.000/2.125 4.000 Collector
154 cranking psi
http://www.maxracesoftwares.com/forum/v ... p?f=5&t=95
This Pump Gas 420cid 711.3 HP engine
was built for a Customer who didn't want to buy Race Gas
.... sort of like see how much HP you can get me on Exxon 93 prem deal .
MaxRace Software
redliner
Post by redliner »
maxracesoftware wrote: Thu Oct 05, 2017 11:39 am
I see the port centerline length you used was different than mine. Does this make a big difference? I am running a ported Motown single plane intake.
maxracesoftware
the Default= 3.200" as its a combination of BBC and SBC centerline lengths average
your Heads are closer to 2.900" Exhaust Port CenterLine Length
so use that Input value
MaxRace Software
redliner
Post by redliner »
maxracesoftware wrote: Thu Oct 05, 2017 12:10 pm here's a 420cid with Pump Gas and 11:1 CR
154 cranking psi
WOW!!!!! VERY NICE!!! Blows my lil 414 outta the water!!!!
redliner
Post by redliner »
maxracesoftware wrote: Thu Oct 05, 2017 12:17 pm
OK Thanks!
In-Tech
Post by In-Tech »
mk e wrote: Thu Oct 05, 2017 11:54 am
I fired up one of my win7 laptops and there it was and yes, very cool. XP doesn't have it. Thanks
Sorry OP for the drag off topic.
-Carl
ptuomov
Post by ptuomov »
RevTheory wrote: Wed Oct 04, 2017 12:04 pm I've heard you want them to hit the collector clockwise but who knows...
And counterclockwise in Australia? ;-)
Put Search Keywords Here
ptuomov
Post by ptuomov »
mk e wrote: Wed Oct 04, 2017 5:38 pm
redliner wrote: Wed Oct 04, 2017 5:33 pm
mk e wrote: Wed Oct 04, 2017 5:24 pm
That sounds like a winning plan!
Programs like dynomation5 (just ordered my copy of dynomation6) or the designs I've seen from places like burns have having at all about order in the collector, but the flow bench and dyno sure say bends matter!
What do they say about the order of the pipes in the collector for my 4/7 swap I'm wundrin...
They don't care about the order of the pipes in ANY setup of any kind. Get the sizes right, use the biggest bends you can and you'll have a good header no matter what order they get plugged into the collect.
The order in itself doesn’t matter but the merge angle probably does matter. I think you want the shallowest or most acute angle of the flow merge for successively firing cylinders. That way, the positive blowdown interference pulse from one cylinder does the least damage to and the flow creates the lowest pressure for the cylinder that’s in overlap. (90 degree blowdown interference at high rpms.). Rotating collector pipe order accomplishes this, because of how the collector angles work. But if you push that thinking further, you’ll end up with 4-2-1headers. Just my opinion.
redliner
Post by redliner »
ptuomov wrote: Fri Oct 06, 2017 8:26 am
The 4-2-1 headers are not out of the question and I have thought about it some.... Which cylinders do I want to pair up when running a 4-2-1 header with a 4/7 swap?
77cruiser
Post by 77cruiser »
Easier to build too. 2-6 & 4-8 1-3 & 5-7, I think just opposite of standard firing order.
Jim
redliner
Post by redliner »
77cruiser wrote: Fri Oct 06, 2017 8:46 am Easier to build too. 2-6 & 4-8 1-3 & 5-7, I think just opposite of standard firing order.
I was thinkin they would make more/ broader power AND be easier to build.... WIN/WIN!!!
