Ti valve modifications...
Ok... So I won a set of RO7 Ti valves on fleabay for a ridiculously low price.
Now what do I do with them...
I sure would like to shorten them to use in one of my oval track project engines... Not so I can run 8 grand but just to get a handle on how they will work in my low budget motors.
They are about an inch too long. I stopped by my local racer friendly machine shop yesterday but he said his machines aren't set up to do the work... He's mostly doing production cnc work now.
So I'm asking for some advice from you seasoned machinists... How can you get this done? What kind of a setup would you need to have?
Can I run these without hard tips but use lash Caps or something like Mantons lash locks ( I know some of the pros and cons of those, too)?
Thanks in advance...
Re: Ti valve modifications...
cut them down and press in these hardened tips
Well that's too easy....
Who makes those caps?
Thanks Pamotorman... These things might work...
An inch is alot to take off of the end of a ti valve. You sure you're not going to be into the moly stem with your valve lock grooves?
Carlquist Competition Engines
Send them to Precision Products in N.C. and tell them what to do.Usually $100.00 a set.You can't put hardened tips in anything smaller than 5/16.
Do this ^^^^^, (have them cut for a radius lock groove) and run standard lash caps.
Pretty common, used to do it all the time with used cup valves.
WarpWarp Speed wrote: ↑Sun Oct 08, 2017 6:17 pmDo this ^^^^^, (have them cut for a radius lock groove) and run standard lash caps.
what is the radius of a radius lock groove
reed
Man at a $100.00 per set I'm still golden... I didn't buy these for any one particular engine... I have two Mopar's that I'm working on for 2018. I guess I'll try to match them up with whatever they will work best on.Warp Speed wrote: ↑Sun Oct 08, 2017 6:17 pmDo this ^^^^^, (have them cut for a radius lock groove) and run standard lash caps.
These Ti intakes are 6.00" long w/6mm stems... the Ti exhausts are 5.70" w/7mm stems. Those 6mm's may be a problem to get fitted for hardened tips... I need them to be about 4.95" for one engine and 5.050/5.075 for another. Std lash caps would work it seems if I can find some. I've been looking thru the Trend catalog tonite doing some planning.
Thanks for all the input...
Last I investigated a similar modification, it was mentioned most TI valves have a DLC coating and disturbing the coating, whether by changing the head diameter or cutting into the stem for a shorter groove is a BAD THING.
Looks like I can get small parts like valves recoated for something like $50.00 or so... I'm going to check with some local outfits around home who do industrial hard coatings to see if they can handle a small order.
http://racetechtitanium.com/shop/index. ... cts_id=570
Would that be per valve, or ??
Don't think so Bill... Not sure how they do the coatings as I believe there are different processes that will work but it seems they do "batches" of parts... I'll call today.
Hope they can do it for you but all the coating shops I've discussed it with say, "No used parts, no way, no how; too much risk of contamination. New, virgin metal only."Krooser wrote: ↑Mon Oct 09, 2017 9:46 pmLooks like I can get small parts like valves recoated for something like $50.00 or so... I'm going to check with some local outfits around home who do industrial hard coatings to see if they can handle a small order.
