SBC mechanical fuel pump oil seal issues
pamotorman
Re: SBC mechanical fuel pump oil seal issues
Post by pamotorman »
the only way the oil can get there is down the push rod or from the pan being forced up the drain hole by G forces in the turns. see if you can put a baffle in the pan to keep the oil from getting into the drain back hole in the turns
ProPower engines
Post by ProPower engines »
There used to be a company named seals it.
They sold a boot type seal that kept the fuel pump from being overwhelmed with oil and pissing out the vent holes.
Not sure if they are still available but we used them for years till 2000 and something when we went to injection.
May be worth a search to see.Buy 2 if you can as they don't last forever but a couple seasons were what we got out of them.
cgarb
Post by cgarb »
leahymtsps
Post by leahymtsps »
FC-Pilot wrote: Tue Oct 10, 2017 10:13 am I have used two dart SBC's and on both the drain back from the fuel pump barely broke through into the crankcase. We had to get the grinder out and open it up. Next time you have the engine torn down you may want to check that. That could definitely prevent proper oil drainback.
Paul
X2 most if not all are like that
Tom
Kev7s
Post by Kev7s »
leahymtsps wrote: Wed Oct 11, 2017 6:25 am
Paul
Tom
Thanks guys ,ill do that over winter I have one race left the weekend, so its almost ready to come out.
