Quaife In-Line 7-Speed Sequential Gearbox
Transmission to Rear-end
Post by pdq67 » Wed Oct 18, 2017 5:28 am
Does anybody make something like this that is strong enough for an American V-8?
"Quaife In-Line 7-Speed Sequential Gearbox - Motorsport ...
https://www.motorsport-tools.com/quaife ... sequential...
The Quaife QBE89G is a seven-speed sequential gearbox with ultra-close ratios, ideally suited to the demands of front engined, rear wheel drive cars running small ..."
And just how does this little transmission work? ------- Like a motorcycle transmission?
Thanks in advance.
autogear
Re: Quaife In-Line 7-Speed Sequential Gearbox
Post by autogear » Wed Oct 18, 2017 12:46 pm
Albins
MTI
Drenth
Hollinger
Quaife
have them; or are all capable of knocking out a sequential gearbox with big shaft centers. You probably need something like 80-90mm shaft centers and spur gears with a coolant pump and DEEP pockets. This is a whole 'nother world than people stuffing spur gears in a modified T10 or Toploader. Serious engineering chops are required.
Seq. gearboxes are a hard sell in the USA, but big business in Aussie V8 Supercars
We looked at it, but the cost to get it off the ground was VERY high
volodkovich
Post by volodkovich » Wed Oct 18, 2017 5:30 pm
Weismann traction products will build you one in the USA. They do amazing work.
WhitleyTune - Bespoke Camshaft & Valvetrain
BigBlocksOnTop2
Post by BigBlocksOnTop2 » Wed Oct 18, 2017 11:18 pm
Wanna see something different, google ZeroShift.
Post by pdq67 » Thu Oct 19, 2017 9:00 am
Albins
MTI
Drenth
Hollinger
Quaife
But just how do these work? By up-shifting and down-shifting through each gear like a motorcycle transmission does? Kind of like a, "ratchet action", through the gears?
autogear
Post by autogear » Thu Oct 19, 2017 9:42 am
TRADITIONALLY there is a racheting drum used to change through the gears, much like a bike.
https://www.youtube.com/watch?v=E1APhLQVtlE
mekilljoydammit
Post by mekilljoydammit » Thu Oct 19, 2017 1:36 pm
With some ingenuity it should be possible to design and make a motorcycle style ratchet shifter actuate shift rods for all of the various transmissions that work that way - there's an Aussie company called Renagate that does one for 4-speeds, and making a version for a 5 speed G-Force or Jerico box shouldn't be that hard. Additionally to the other companies mentioned, there's Saenz who have a 5 speed sequential they say will handle 700 ft/lbs.
j-c-c
Post by j-c-c » Thu Oct 19, 2017 2:06 pm
Every time I investigated Seq boxes, the torque ratings where on the low side for healthy V-8's, and a bit pricey downstroke when in the over 500ft/lb range. That will decrease i expect overtime stating the obvious.
autogear
Post by autogear » Thu Oct 19, 2017 2:51 pm
Another add-on kit is the SSS Sequential Shifter for the T56
Post by MadBill » Tue Oct 24, 2017 7:23 pm
HGT claims 738 lb-ft. capacity (and I understand a 1,000 lb-ft. one is in the offing) http://www.hgtprecision.com/products/ge ... smissions/
mekilljoydammit
Post by mekilljoydammit » Wed Oct 25, 2017 12:57 pm
I'm in sort of the opposite boat - it seems like there's very few good racing (dog box, straight cut gears, capable of having a 1st gear around 2:1) H-patterns made these days and about zero 6-speed ones.
Post by MadBill » Wed Oct 25, 2017 9:16 pm
After blowing up ~ $10,000 worth of face-plated/dog box converted) TKO 600s in our 380 c.i. 700 HP/550 lb-ft. SBF road racer in three years (the last two survived a total of 14 laps), we went with a G-Force GSR H-pattern 4 speed box from http://www.racetechservicesinc.com/. this year. Flawless to date!
We use a 1.93:1 1st, but they offer 12 other choices, from 2.48 to 1.80. Since the car is capable of almost 100 MPH in 1st, we could do with a 'pit creeper' bull-low, but the clutch has held up so far...
j-c-c
Post by j-c-c » Thu Oct 26, 2017 11:01 pm
I saw that at PRI, last? year, looked like it was fairly new when I spoke them, heard any real world reviews yet?
RW TECH
Post by RW TECH » Fri Oct 27, 2017 12:53 pm
kimosabi
Post by kimosabi » Fri Oct 27, 2017 6:12 pm
http://www.samsonas.com/
Takes a whole bunch of torque.
