how to adjust valves on ford big block solid roller cam
chevy art
Post by chevy art »
cam you adjust big block ford (460 cubes) with a solid roller the EOIC way or i there another way. im a chevy guy and adjust my solid roller the EOIC way. thanks art
cjperformance
Re: how to adjust valves on ford big block solid roller cam
Post by cjperformance »
Thats the simplest way with any big duration cam to make sure you're not near the lobe ramp when you adjust.
The EOIC approach works for any four stroke poppet valve engine.
cjperformance
MadBill wrote: Sat Oct 21, 2017 11:47 pm The EOIC approach works for any four stroke poppet valve engine.
Exactly, on small cam stuff i simply adjust at tdc on comp stroke, quick simple and fine for shorter duration but not as foolproof on big duration lobes as eoic way.
ingram
Post by ingram »
cjperformance wrote: Sun Oct 22, 2017 12:02 am
If the piston is at T.D.C. on the compression stroke, both valves are closed.
Ingram Engineering
Cam Profile Designs
www.camprofiledesigns.com
True, but unless the engine has a degreed and clearly visible damper, it's easier to reference the adjacent rocker. (plus you don't have to keep dodging back and forth from viewing the damper position to accessing the rocker)
chevy art
Post by chevy art »
thank you guys. i figured the EOIC way would work on the ford. but just wasnt really sure. i appreciate the replies. art
cjperformance
chevy art wrote: Sun Oct 22, 2017 11:28 pm thank you guys. i figured the EOIC way would work on the ford. but just wasnt really sure. i appreciate the replies. art
Hey ,, just remember #1 is on the correct side of the engine on the Ford ! :lol:
