8620 steel camshaft
1972ho
8620 steel camshaft
Post by 1972ho »
Do they make this type metal camshaft for flat tappet solids,and if so what do they sell for.
Walter R. Malik
Re: 8620 steel camshaft
Post by Walter R. Malik »
1972ho wrote: Sun Oct 22, 2017 12:57 pm Do they make this type metal camshaft for flat tappet solids,and if so what do they sell for.
I know they used to ... I have a couple older NASCAR cams like that on the shelf right now.
1972ho
Post by 1972ho »
Are the ones you for a ford.
Charliesauto
Post by Charliesauto »
Yes in 8620, will cost you 850-1000, depending on what kind of deal you are on with the manufacturer.
Also can get tool steel core which will be thru hardened, cost you 1200-1400.
Both have to be polished to a pretty low RA and both need coated(DLC etc.) lifters, another 1200+.
A side benefit, you can run either in needle type cam bearings if you want.
Big money up front but probably worth it if you are really gettin after it.
hoffman900
Post by hoffman900 »
LSM will make them for you. Last time a friend bought them, they were $600ea / minimum order of 5. That is just the blank - pre actually grinding any lobes on them. This was also about 5 years ago.
So you’ll be in about $1000-1200 for the cam alone, each.
He had Crane (Chase Knight spec), Crower (with Bruce picking out the numbers), and LSM all grind one of each. All were with a couple degrees of duration at .050”, a few thousands of lift, and 2* LSA from each other. =D>
-Bob
Mark O'Neal
Post by Mark O'Neal »
I should have made 8620 cam cores instead of wrist pins.
CamKing
Post by CamKing »
We have the cores on the shelf(depending on journal size) for SB Chevy, and Ford 351w.
For a finished cam, you're looking at between $700-800
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
1972ho
Post by 1972ho »
What about the 351 Cleveland
CamKing
Post by CamKing »
1972ho wrote: Thu Oct 26, 2017 2:31 pm What about the 351 Cleveland
We would have to machine the core. The price would be the same, but it would take a couple more weeks.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
