Who's making Jegs Oil Pumps?
rapidride2
Post by rapidride2 » Wed Nov 08, 2017 6:43 pm
Anyone know who is making Jegs "Made in USA" oil pumps? Looking for something for a stock type sbc overhaul.
cgarb
Re: Who's making Jegs Oil Pumps?
Post by cgarb » Wed Nov 08, 2017 7:06 pm
I would be willing to bet Melling. If you look closely in some of the picture they have the Melling numbers cast into them.
rapidride2
Post by rapidride2 » Wed Nov 08, 2017 7:09 pm
You sure are correct. After a closer look i see a 55 on the pump.
WeingartnerRacing
Post by WeingartnerRacing » Wed Nov 08, 2017 11:43 pm
I just put one in my last motor. Kinda pissed me off because it’s a Melling. The old ones were totally different they were thicker so much so I had to grind it to get it to clear the main studs. Much better product.
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
cgarb
Post by cgarb » Wed Nov 08, 2017 11:53 pm
Was that one of the ones that were supplied with 3 different pressure relief springs?
travis
Post by travis » Thu Nov 09, 2017 12:59 am
So are these reboxed Mellings products, or built to Jegs specs like Walmarts name brand products?
rapidride2
Post by rapidride2 » Thu Nov 09, 2017 6:13 am
And here it comes..
Any other suggestions than melling for a 250hp 305 chevy overhaul?
I've heard enough of the negative on today's mellings.
cgarb
Post by cgarb » Thu Nov 09, 2017 6:39 am
I like my Milodon pump for my 377 SBC. Standard volume high pressure. For just a standard rebuild I would just get a standard pressure.
rapidride2
Post by rapidride2 » Thu Nov 09, 2017 2:08 pm
I've heard complaints about Milodon as well. Basically people paying $40-$50 dollars more only to reveal it's an overpriced Melling pump as well.
cgarb
Post by cgarb » Thu Nov 09, 2017 2:22 pm
No, different casting. Mine is not a Melling. I did take mine apart and do some deburr on it and clean it up some more. Found a few chips inside. That's SOP for me with oil pumps so it's not a huge deal.
Jeff Lee
Post by Jeff Lee » Thu Nov 09, 2017 2:22 pm
And I lost a really good engine due to the Melling supplied pressure relief spring fracturing. It’s your typical China crap. Better off with a 150,000 mile junkyard OEM factory installed used spring. Or consult McMaster or other source for a true quality part.
I’ve heard of this issue on numerous Detroit brand engines.
NHRA SS/H
1970 AMX
390 4-speed
Advanced Clutches
Red Line Racing Cams
engineguyBill
Post by engineguyBill » Thu Nov 09, 2017 9:24 pm
Yes, I think most of the private-label oil pumps currently on the market are manufactured by Melling. Hoof used to have a lot of that business when they were around, but no longer.
Bill
SAE Member (28+ years)
"Do what you can, with what you have, where you are."
- Theodore Roosevelt
In-Tech
Post by In-Tech » Thu Nov 09, 2017 10:05 pm
Isn't Elgin still in the hunt?
-Carl
GARY C
Post by GARY C » Thu Nov 09, 2017 10:16 pm
I have always run stock BBC pumps on SBC with no issue, 7500 rpm eight mile nitrous stuff, it requires the specific shaft and pick up.
cgarb
Post by cgarb » Thu Nov 09, 2017 10:25 pm
I have a stock BBC pump on my stepbrothers 355, been working good for 3 years now. Everyone has a different theory with oil systems and when set up correctly most of them do work well. Kind of funny though how someone can have trouble and swear that a (example) high volume pump sucked the pan dry. Someone else won't use nothing but high volume pumps without issue ever.
