Adding Oil Pan Baffles and Trap Doors
BBO Omega
Post by BBO Omega » Fri Nov 10, 2017 12:55 pm
Is there any "Pattern" acailable for adding Trap Doors and Baffles to a square bottomed Oil Pan? What is best used for a Trap Door. Most I have seen look like door hinges.
73 Omega, 468 BBO, 4.185 ICON Pistons,RR/Wenzler Heads with HS 1.7 rockers and PAC 1220X Springs,J&S 5-main Halo with Billet Caps, .590I .580E 242I 256E HR Cam, 1000hp Carb,2" x 3 1/2" headers,Coan 2900rpm Conv.,TH400,3.73 12 bolt,11.32/118
ptuomov
Re: Adding Oil Pan Baffles and Trap Doors
Post by ptuomov » Fri Nov 10, 2017 3:04 pm
BMW uses rubber flaps from the factory. They believe they are superior to metal doors. Same style also available in bulk from I think Tomei?
[b]Paradigms often shift without the clutch[/b] -- [url]https://www.youtube.com/watch?v=cxn-LxwsrnU[/url]
RCJ
Post by RCJ » Fri Nov 10, 2017 4:34 pm
Speedway had a kit to add on to a sbc,it was around $25 .Had a trap door and a kickout.Worked good as long as you had the oil pan bolted to a block when welding.
ProPower engines
Post by ProPower engines » Fri Nov 10, 2017 4:47 pm
Stainless piano hinge is what is used in most pans with the pin replaced with a smaller sized wire to allow if to move freely and stop before jamming open.
ptuomov
Post by ptuomov » Fri Nov 10, 2017 5:02 pm
This is what is in my car right now. I believe it works better with these (sump cover and walls with flaps) than without them. Front sump and pickup.
